Old 01-17-2007, 07:29 PM
Edson Edson is offline
Default presonus tube pre amp
Can somebody help me out. I'm using a presonus tube pre amp to record harp and for some reason it's distorting, even when i have the gain down at 10:00 with the Pad switch activated. Is that normal? Should I not use a tube pre for recording harp and just use it to record vocals? I'm new to this stuff....
thanks,
edson
www.myspace.com/kidboy
Old 01-17-2007, 07:35 PM
Craig F Craig F is offline
Default Re: presonus tube pre amp
could it be the mic distorting before it gets to the pre?
It would help if you included mic type and position.
Thank you,
Craig
Old 01-17-2007, 07:44 PM
I'm using a ADK Vienna, mic position is about 8 inches from harp soundboard, and once i disconnected the preamp the distorting went away...
any opinions>?
Old 01-17-2007, 11:00 PM
cfb25 cfb25 is offline
funky tube in the presonus?? I had a presonus.. After about 6 mos my tube went out, I put in a nice NOS something, i don't remember... But it did the trick..
Chris Beaver Music
www.myspace.com/chrisfrankmusic
The Note Music
www.myspace.com/thenotemusic
Dual 2.0Ghz PPC 3gb Ram, Digi 002R
Old 01-18-2007, 09:44 AM
BRH BRH is offline
Sure you're not running line out from the presonus to mic in on your interface? Should be line out to line in.
PreSonus Tube Preamplifier Help Big Fate 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 04-22-2011 05:27 PM
Presonus Firestudio Tube with PT9 nohayniunnick Pro Tools 9 6 11-24-2010 07:43 PM
presonus tube pre amp "tube" Edson Pro Tools TDM Systems (Mac) 4 01-19-2007 10:20 AM
Presonus Tube Pre and 002r Joe Evans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-24-2004 01:27 PM
PRESONUS BLUE TUBE gtrman79 General Discussion 1 07-14-2003 07:22 PM
