MBox Mini (3rd gen.) 1.1.7 driver causing BSOD
After installing the new driver I had high hopes, because the previous version had problems with ASIO on Win7x64, so I had to reinstall the driver every odd time after I restarted the computer and wanted to do some tracking.
Now I'm not tracking at all, because the new driver (1.1.7) causes a BSOD every so often (around every half an hour, it depends on how much I switch between different audio applications). It's the same on Win7x64 and Win8, genuine and fully updated. Anyone having the same problems and, better, knows how to solve them? |
Re: MBox Mini (3rd gen.) 1.1.7 driver causing BSOD
Can you post the details of the BSOD? What file is causing it? Also you might want to do a memory test just to be sure:http://www.memtest.org/
Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
I've uploaded the memory dump files HERE, and i'm pretty sure it's the driver that's causing the BSODs, because the problems appeared instantly after installing the latest driver. Also, Win8 has a bit more sophisticated BSOD that actually wrote out that it was the MBox driver that caused the fault (instead of just giving me the exit code and a generic error descripion, like Win7). If you need any additional data please ask, I will provide anything that can be of use to you. Thank you for the quick response! Z |
dalwdm.dll causing 6031 error and BSOD | majorlabel | Windows | 19 | 09-07-2012 03:35 AM |
dalwdm.dll causing 6031 error and BSOD | majorlabel | Windows | 0 | 06-27-2012 06:02 PM |
BSOD when reinstalling Mbox 3 Mini driver*Sandra report included | davidleecarter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-24-2011 12:44 PM |
Mbox driver causing kernals & crashes | yanncrusoe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-20-2009 12:20 AM |
Could my Mbox mini be causing the 6086 error? | flash0669 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-03-2008 07:21 PM |
