Old 02-13-2024, 08:05 AM
TCX TCX is offline
Default Midi Prefs Missing
If Protools wasn't so expensive, and didn't sell itself as a premier Midi platform, I wouldn't find these kinds of omissions so, uhm...interesting. Where are these checkboxes (on and off switching)? Thanks
Reset on Stop
Send out MIDI reset messages, including note-off and controller resets, on stop.
Never Reset Chased Controllers
Never resets controllers to 0 when you stop playback or move to a new position in the project.
Chase Events
Chases event types for which one of the chase options is activated when you locate to a new position and start playback. This makes your MIDI instruments sound as intended when you locate to a new position and start playback. If Chase not limited to Part Boundaries is activated, MIDI controllers are also chased outside the part boundaries, and the chase is performed on the part under the cursor as well as on all the parts to the left of it. Deactivate this for very large projects, as it slows down processes like positioning and soloing.
Old 02-13-2024, 08:28 AM
tope d's Avatar
tope d tope d is offline
Default Re: Midi Prefs Missing
Reset on Stop
Chase Events
For the second one, is it similar to the Insertion Follows Playback option?
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 02-13-2024, 09:16 AM
skylar_battles skylar_battles is offline
Pro Tools has MIDI chase. Enabled by default always on instruments tracks, it can be turned off if working when using loops in a sampler if desired.
Pro Tools Ultimate 2024.3.1
MacBook Pro 16"
Apple M2 Pro with 12‑core CPU, 19‑core GPU, 16‑core Neural Engine
32 GB unified memory
1TB SSD storage
Ventura 13.6.4
Old 02-14-2024, 08:16 AM
TCX TCX is offline
Samplers are a different subject/context. Is there an off switch for midi track chase? Where do you see that? Thanks
Old 02-14-2024, 08:26 AM
TCX TCX is offline
Doesn't seem to be related.
The larger point, which is amply confirmed by looking through midi threads here, is that there is not enough love applied to PT Midi from top to bottom. Tons of love for collaboration features though. It's an unfortunate choice.
"Reset controllers/notes on stop" option missing.
So basic.
Old 02-14-2024, 02:52 PM
When you click the upside down triangle on the track header, you can see that "Note Chasing" is enabled by default. There is also an option called "Pitched" which effects how particular MIDI and Instrument tracks respond to the "Key change" dialog. It should be turned off with samplers so you don't lose mapping when using the key change dialog. Note-chasing is usually desired except when it triggers a sequence of loop "incorrectly" which is why the manual specifies not to use it for that situation.
MacBook Pro 16"
1TB SSD storage
Ventura 13.6.4
Trashing Prefs & Restoring Prefs - Sticky? quangaroo macOS 9 11-24-2018 10:43 PM
midi realtime properties Prefs? mickblah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-26-2008 05:06 PM
Missing I/O Settings and failure to save Prefs PioneerPilgrim Pro Tools M-Powered (Win) 1 08-30-2007 08:57 AM
Reason Prefs show no MIDI input Voxer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-02-2005 04:17 PM
No Sound-help!! After deleting Digisetup, PT prefs and DAE prefs bigthinka9 Pro Tools TDM Systems (Mac) 6 10-24-2002 07:41 AM
