PT 2023-12 weird "select between markers" issue
using regular old location markers. nothing fancy. opened an existing PT session from 2023-9. Mac Ultimate could not: select a marker, (by clicking on a marker in marker window) hold shift ... then select a different, later marker, (by clicking on a marker in marker window) ...and have it select the time line between it (and hit option F to see only that section in edit window) the issue is it weirdly did not select the time line (edit window) inbetween my start and end marker (as it should) have been doing this same thing for decades.... no issues. what am i missing? reopened PT 2023-9, worked as always has, resumed work. |
Re: PT 2023-12 weird "select between markers" issue
must be an easy fix... a new preference i am unaware of?
otherwise 2023-12 seems solid. would like to use it. some neat new features.... |
Still getting my feet wet with Pro Tools 2023.12 but I did get a note just now from one of our best engineers regarding your query. :). Apparently, you can now shift+click in the far left column of the memory location window to do this. This column ( left ) is now responsible for recalling the memory locations, whereas the right area selects the memory locations in the window. You can link the selection and recall, but when it comes to shift click to recall and select on the timeline, you need to explicitly shift click in the left column. Hope this helps and I love it -learn something new every day peeps. Thanks and happy holidays. Marianna
Marianna Montague Sr. Dir. CX and Community | Customer Advocate [email protected] cell +1 (813) 493-6800 AOL IM avidmarianna Twitter Avidmarianna We're Avid. Learn more at www.avid.com |
I thought I was the only one...
we'll learn the new habit...
http://www.stevegalante.com |
Bit annoyed that I had to Google why my Markers workflow had changed for the first time in the best part of two decades but c'est la vie. Thank goodness for this group.
Drink up, dreamers... you're running dry |
Agreed.
Custom i9-12900K, 64GB RAM, W10 Pro, PT Ultimate 2024.03, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7 |
yes, and yes!
Hi Marianna,
Whats the purpose of that new column? can I remove it? thanks Quote:
Hope that helps.... Marianna
"Select Assignments to" does "Select & Show Hidden Tracks" instead! [PT-263050] | Electronic1982 | Pro Tools | 6 | 12-17-2023 04:02 AM |
Issue with "Select All" and MIDI regions (extra padding after region) | George Benson | Pro Tools | 5 | 10-07-2023 01:37 PM |
Pro Tools 2023.6 - Remove "Track Name" column from Memory locations window | ralphonz | Pro Tools | 10 | 09-24-2023 04:38 AM |
"Back and Play" keyboard shortcut gone after update to 2023.6 | mr xy | Pro Tools | 6 | 06-20-2023 09:51 AM |
Weird issue with "all" group in large PT 9 HD session | innerbooty | Pro Tools 9 | 1 | 05-08-2016 10:34 AM |
