Audio goes out of sync whenever I recall a plug-in settings
Whenever I recall a plug-in setting my audio goes out of sync and I have to remove all the plug-ins and add then one by one. Can anyone tell me why this may be happening?
Re: Audio goes out of sync whenever I recall a plug-in settings
plugin setting? As in a saved preset?
Do you have Delay Compensation turned on? What plugin specifically? Probably need a little more info to go on. |
Yes, as a saved preset (attached a pic all the plug-ins I recall) and again when I recall the plug-ins it cause any audio recording to go out of sync.
So to be clear, you’re talking about a Track Preset?
Post a picture of your delay compensation for the track. That pic doesn’t really show much other than you have a lot of plugins on one track that might be exceeding the delay compensation limit. |
How many plugs are in the VMR?
__________________ Al Hospers bassist, vocal, composer, engineer https://www.youtube.com/channel/UCCw...ogfR_7Q/videos ------------------------------------------------------ PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones... |
Ok, I didn't even know what delayed compensation was until I looked it up and I see one plug-in is causing the delay once I removed it.
It’s not a matter of just one, it’s the combination of all plugins on the track and their combined delay. You have a certain amount of delay compensation available per session.
Just one but I see it's the problem is the T-Racks Stealth Limiter. Was weird is that I don't have this problem in Logic.
So I'm limited to the amount of plug-ins I have in a track preset.
And yes I understand that it's all the plug-isn that cause that together. Thank you
How to save and recall plug-in settings | Paul Maunder | Getting Started | 2 | 11-15-2016 05:02 AM |
Recall of the settings | apples_oranjes | General Discussion | 7 | 06-02-2015 06:03 AM |
recall PRE settings | pmueller | Pro Tools TDM Systems (Mac) | 4 | 05-27-2008 05:51 AM |
Any way to recall AudioSuite settings on a single region? | TQ1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-19-2007 10:50 AM |
DAE 3.4.2f9 / Waves 2.7 Recall Settings Fix | Techsupt2 | General | 0 | 09-08-1999 03:14 PM |
