Old 03-18-2018, 11:36 AM
ryane24 ryane24 is offline
Default Reamping/hardware insert question
Hey folks. So I was trying to run the high end of my bass through just my amp head with the eleven rack. I'm sending a bass DI out the reamp out on the front to the amp head and then out the DI on the back of the amp into the main Mic Pre on the eleven rack. At first I was trying to do it as a hardware insert but the inserts are just Insert 1 (mono), Insert 2 (mono) etc. I don't know what these actually correspond to. Sooo, I tried setting it up on an aux track. I just made the output of the bass track the reamp out and the input of the aux track the mic pre. It works, EXCEPT there is a massive delay. Tips?
Old 03-18-2018, 01:02 PM
zedhed's Avatar
zedhed zedhed is offline
Default Re: Reamping/hardware insert question
I'd like to be able to help but I'm finding it difficult to understand your routing, not what you've done but why.
Exactly what are you trying to achieve?
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 03-18-2018, 01:44 PM
Benoni's Avatar
Benoni Benoni is offline
What do you mean the "high end of your bass"? In terms of frequency?
And why that routing?
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 03-18-2018, 04:26 PM
Okay. I didn't think the details of why I'm doing it we're really important but I will explain anyways. There is a very common technique of duplicating your bass DI. Hi passing one and low passing the other so you can treat the high-end and low-end individually. I'm trying to use my real amp head the same as I would use an amp sim in this context - as a plug-in inserted on the track. My amp has an output that allows you to run the amplified signal without a cabinet so you can use a cabinet IR instead. SO as I said before, I am sending the already recorded bass DI in Pro Tools out the reamp out of the eleven rack into the amp. Then out of the amp into the mic pre on the eleven rack.
Old 03-18-2018, 04:41 PM
BScout BScout is offline
What is your buffer setting? You are hitting it at least twice compared to the original. 4 times if you were playing live through it (input from bass, output to reamp, return from mic, output to speakers.) So turn your buffer down as low as you can.
Otherwise, set up the reamp as a insert on the insert tab in i/o setup. The inputs and outputs need to be the same (say you go for the insert on outputs 3-4, you get your signal back on inputs 3-4) and then put in the delay on the H/W insert delay tab for that hardware loop. If you are going out 3-4 but returning 1-2, this isn't going to work. You'll have to do it the way you are doing it currently. Then you'll have to manually key in the delay compensation for the aux channel in the delay area of the mixer page. Won't get around delay but will put everything back in sync.
Pod HD Pro as hardware insert/reamping device in PT11 Equinoxps Windows 0 03-03-2014 11:46 AM
OMNI ADC and Hardware insert question K Roche Pro Tools HDX & HD Native Systems (Mac) 4 03-06-2011 05:21 AM
Hardware Insert question mcbv 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-02-2007 08:08 AM
Hardware Insert Question Eless 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-05-2006 07:32 AM
Hardware insert question jwd65 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-14-2006 05:12 AM
