Are Digi003 line inputs TRS?
The specs say "balanced", so XLR out from a preamp to TRS into the 003 line input should bypass the onboard preamp - right?
Thanks.
003 Factory PT LE 7.4 Intel Core 2 CPU 6320 @ 1.86GHz Gigabyte Technology G33M-S2H 2GB DDR2-SDRAM XP Home 5.01.2600 (Service Pack 2) |
Re: Are Digi003 line inputs TRS?
Do you mean line-input or DI input? The line inputs 5-8 have no associated preamps and are just line inputs. The "DI" inputs 1-4 go though a preamp and there is no way to remove that from this circuit (you can choose to use the Mic or DI but in both both cases the preamp circuit is involved). If you need to you can take a line in input to a DI input, the gain may be a bit higher than you want. And DI 1-4 are balanced. If you connect say an unbalanced guitar the mono 1/4" phono plug will just short the negative signal side to ground. All this is covered in the manual (maybe not clearly enough, but it is in there). And has been mentioned on there forums many times before. You may get more useful advice if you said what you are tying to do. Darryl |
I don't believe you can bypass the pre's
All correct^^^, but you can feed the line output of an external preamp to the TRS inputs(all 8 of them) without issue(I do it every day here, with balanced cables)
digi003: hum on inputs 1-4 ? HELP !!!! | jaunmanuek | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-10-2009 01:38 PM |
Pre-Amp / AD for my SPDIF inputs on Digi003 | AndyJCP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 08-08-2009 01:32 AM |
PT8 on a DIGI003 Rack: Why am I only getting 2 inputs present on the input tab. | sharpo07 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-28-2009 02:09 PM |
Monitor Mode inputs 3-4 on the Digi003 Rack | 29th of July | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-26-2009 04:12 PM |
Digi003 Mic inputs 1 thru 4 | allegrarc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-13-2008 07:29 PM |
