Old 10-31-2011, 07:09 AM
Milko71 Milko71 is offline
Default PT9 don't shut down correctly!
Hi there,
I'm using PT9 with a Focusrite Liquid Saffire 56. After a lot of troubleshooting it works pretty well, except when I use an instance of my Focusrite Liquid Mix. During using it all looks fine, but when I shut down Pro Tools en I want to start Pro Tools again it said: "Pro Tools did not shut down correctly the last time it run. You need to reboot your computer if you want to run Pro Tools again" or something like that
I'm using is on Windows 7 64 bit. I guess it's not PC hardware dependent, because my old PC has the samen problem (that's why I bought an new PC )
Does anybody has the same experience and is there any solution??
Thanks,
Milko
Pro tools did not shut down correctly! Raoul23 Windows 41 03-08-2016 04:16 PM
G5 Fan Won't Shut Off Oddeo154 Pro Tools TDM Systems (Mac) 10 01-04-2011 12:58 PM
help - cant seem to pan correctly t ho 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-08-2002 06:44 PM
"ProTools did not shut down correctly" writethis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-07-2002 06:47 AM
G4 won't shut down KSutton General Discussion 11 08-24-2001 07:55 AM
