magma chassis questions
I'd like to use a Magma expansion chassis to host my pci-x hd3. (The reason being, my computer died, the hd is fine but I had to get a new cpu, and there's nothing with pci-x anymore).
So, if I may, a few questions: 1. I'd heard there is an issue that renders the older 7-slot expansion chassis useless for pt9. What is is this issue exactly? Does it apply to the 64-bit version as well? 2. I notibe the pe6r4 is the only one with a x8 pciE host. Is this significant? 3. What if I want to connect this whole system into a laptop, can it be done? Thanks! |
Re: magma chassis questions
look at my signiture im using a HD3 system with a supermicro board i built this about 6 months ago and it rocks and was way CHEAPER than a chassis
regards
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
It's no supported but I use a p7r464 chassis to host my hd 4 accel and it works really well. Major advantages would be expandable to hd 7 and future proof due to you only need one pci slot to run it.
Are you using the third card in the 32-bit slot?
Raoul Crane
Regards
Raoul Crane
If you search on ebay, you can find an Gigabyte GA-H55-USB3 rev 2.0 with 3 PCI slots / 4 PCI-E slots and it works fine in my set up with an older cream colored Avid PCI 7 slot expansion chassis. I bought this mobo cause I read on a Hackintosh forum that it work excellent for that purpose as well as the three PCI slots would work without flaws in an HD3 set up without an expansion chassis (even though I use an expansion chassis it fired up the first time I installed PT HD, I had problems with other mobo and issues when I installed more then 1 UAD2 card in the mobo) All I can say is it made PT HD life alot easier for me compared to the headaches I went through with 2 other mobo's.
I wrote a little bit about it here http://duc.avid.com/showthread.php?t=308593 ...I'm glad I bought it now.
What is more relaxing than Music? Pro Tools Carbon for macOS 12.7.4 My HDX for Windows11. Gigabyte Z490 Vision D - BIOS F21b Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1) Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity Bricasti M7 (2) Lexicon PCM96 Neumann KH805 - KH310 Yamaha NS-10M Avantone Mixcubes Grace Design M905 Etc, etc, etc. |
I currently run windows 7 64 bit but I've also used osx 10.6.2 with this system. Both seem to work very well.
Im running a PT HD2 rig in a Magma PCI7RX. I have an i7 2600K on an Asus P8Q67-M. The Magma PCI host card is sitting on the 2nd PCI slot on the mobo. The OS is Windows 7 x64, PT is 8.1.1 HD. Everything is running like a charm. I only had to replace the PSU and all fans of the Magma chassis as it was a way to noisy.
Oh I forgot, I had to put PT Cards in different order, which means Accel Card on the first slot (right after the Magma controller card), then the Core Card. |
That's good to hear. Could you do me a favor and push your HD2 card to max (Voices and Plugins) or close to it and tell me what is your PCI % in the usage window so I can try to compare something against what's happening in my system....thanks.
Magma P13r PCI expansion chassis questions | John_Toolbox | Pro Tools TDM Systems (Mac) | 7 | 07-20-2012 12:05 PM |
Magma Chassis HD8 and UAD | stewkirkwood | Pro Tools TDM Systems (Mac) | 5 | 07-25-2009 05:26 AM |
Digidesign Chassis? Magma Chassis? | BigEvil | Pro Tools TDM Systems (Mac) | 13 | 12-13-2008 10:53 AM |
New Magma PCI Express chassis-Questions | Armando | Pro Tools TDM Systems (Mac) | 1 | 06-26-2008 07:57 AM |
Magma Chassis | profesrgeo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 09-24-2003 01:10 PM |
