Upgraded to Pt9 and Saffire 56++
Hi.
I just upgraded my studio with Pt9.03, Focusrite Saffire 56 + Octapre MKII Dynamic, Win 7 64bit ultra. My computer is an apporved Dell but when I try to open a new project in 24bit 48k it tells me that there has been changes and I need to restart PT. I checked in the Session view, and it says 48k, 24bit. Now, I checked Control Panel (sounds), set it to 24, 48k. I did all the optimalizations for PT. The saffire app, set it to 48 and when I open a project I set it to 48k. I have checked that saffire is the soundcard in PT and it finds all my IOs etc. All databases, all is deleted. Tried different startup procedures..... I'm not using my old Digi002 and havn't installed the driver for 002 and firewire. AND, YES I do have backup of my old system :) Other apps like Wavelab works fine. What am I missing? |
Re: Upgraded to Pt9 and Saffire 56++
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
Not sure if this has anything to do with your problem, but you might try an alternate firewire driver such as the legacy one. I bought a Saffire 56 recently and love it!
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
When you change start a new session, you must specify the sample and bit rate. If you start a session and change the sample bit rate settings, it must be from the settings, playback engine menu. It will ask you to restart PT. Save it first and exit. When you open the session, make sure that the settings for your Saffire is already @ 24bit/48k otherwise ProTools will reset the sample/bit rate and it will ask you to restart again.
Intel i7 4770 Dell XPS 8700 16 Gig DDR3 1 x 1TB System Drive 1 x 320Gig Seagate HDD 1 x 500Gig Seagate HDD UAD-2 Solo Steinberg UR44 KRK RP5 Windows 10 Pro. 64 bit Sonar Platinum Cubase 8 Sony Acid Pro 7 Sampletank 2 XL EZDrummer Guitar Rig 5 ProTools 12.3 All legit software thank you very much. Yes I have a low post count but only because I don't have a lot of problems with my gear. |
Thansk:
Cwsand, yes legacy is one of the optimalization settings. Done. Dism, I actually didn't try to do a save. I will try. |
My finding so far:
I have 2 monitor 1x24" (1920x1200) and 1x19" (1280x1024). When PT starts it sets the PT windows to the same size as my 19". If I adjust this PT window to match my 24, pt comes up that I need to restart because of ASIO changes. I have disconnected my 19" and all works OK now. I have a Nvidia Quatro 4800 with the newest drivers. Driver only installed! My 24" is connected through the Digital out, and my 19" to display port->digital converter. These are the alternatives I have for connecting.... I will try another 24" to replace my 19" to see if this helps. |
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
I will try with two 24" tomorrow (tuesday).
I have managed to get a stable Pt9 now with only 1 monitor. |
Two 24" with 1920x1200 works better and stable, sort of.
If I max out the PT windows to fitt both monitors 100%, it fails. If I keep just a little on the bottom left, just some pixels; it's stable. Go figure. I will try the old gfx card tomorrow (quatro fx.xxx, can't remember). |
Not so happy anymore. It fails all the time. Did get a Sandra repport:
SiSoftware Sandra Computer Model : Dell Precision WorkStation T5400 Workgroup : WORKGROUP Host Name : StudioValhalla1 User : StudioValhalla Processor Model : 2x Intel(R) Xeon(R) CPU E5440 @ 2.83GHz Speed : 2.83GHz Cores per Processor : 4 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 Cache : 2x 6MB, ECC, Synchronous, ATC, 24-way, 64 byte line size, 2 threads sharing Computer Mainboard : Dell 0RW203 BIOS : Dell A04 08/21/2008 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : 2 Processor(s) Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 4GB DDR2 FB-DIMM Chipset Model : Dell 5400A Chipset Memory Controller Hub Front Side Bus Speed : 4x 332MHz (1.33GHz) Total Memory : 2GB DDR2 FB-DIMM Channels : 2 Memory Bus Speed : 2x 332MHz (664MHz) Memory Module(s) Memory Module : Samsung M395T5750EZ4-CE66 1GB ECC DDR2 FB-DIMM PC2-5300F DDR2-666 (5-5-5-15 3-20-5-3) Memory Module : Samsung M395T5750EZ4-CE66 1GB ECC DDR2 FB-DIMM PC2-5300F DDR2-666 (5-5-5-15 3-20-5-3) Video System Video Adapter : NVIDIA Quadro FX 4800 (192 SM4.0 1.19GHz, 1.5GB DDR3 1.58GHz 384-bit, PCIe 2.00 x16) Video Adapter : NVIDIA Quadro FX 4800 (192 SM4.0 1.19GHz, 1.5GB DDR3 1.58GHz 384-bit, PCIe 2.00 x16) Graphics Processor OpenCL Processor : NVIDIA Quadro FX 4800 (192SP 24C 1.2GHz, 1.5GB DDR3 1.58GHz 384-bit) Compute Shader Processor : NVIDIA Quadro FX 4800 (192SP 1.19GHz, 1.5GB DDR3 1.58GHz 384-bit) CUDA Processor : NVIDIA Quadro FX 4800 (192SP 24C 1.2GHz, 1.5GB DDR3 1.58GHz 384-bit) Storage Devices Corsair CSSD-F120GB2 (120GB, SATA300, SSD) : 112GB (C:) (D:) SAMSUNG HD103SJ (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) : 932GB (G:) (H:) (I:) Seagate ST3500320AS (500.1GB, SATA150, 3.5", 7200rpm) : 466GB (J:) (K:) (L:) (M:) HL-DT-STDVD+-RW GSA-H31L (SATA150, DVD+-RW, CD-RW, 2MB Cache, 32MB Flash) : 111MB (E:) Optiarc DVD RW AD-7170S (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:) Logical Storage Devices System Reserved : 100MB (NTFS) PTaudio (G:) : 244GB (NTFS) @ SAMSUNG HD103SJ (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) Work (J:) : 49GB (NTFS) @ Seagate ST3500320AS (500.1GB, SATA150, 3.5", 7200rpm) GHOST (K:) : 49GB (FAT32) @ Seagate ST3500320AS (500.1GB, SATA150, 3.5", 7200rpm) Data (L:) : 149GB (NTFS) @ Seagate ST3500320AS (500.1GB, SATA150, 3.5", 7200rpm) PTbackup (M:) : 150GB (NTFS) @ Seagate ST3500320AS (500.1GB, SATA150, 3.5", 7200rpm) SSD win7 (C:) : 78GB (NTFS) @ Corsair CSSD-F120GB2 (120GB, SATA300, SSD) SSD 2 (D:) : 34GB (NTFS) @ Corsair CSSD-F120GB2 (120GB, SATA300, SSD) Samples (H:) : 15GB (NTFS) @ SAMSUNG HD103SJ (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) Morro (I:) : 673GB (NTFS) @ SAMSUNG HD103SJ (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) Saffire MixContr (E:) : 111MB (CDFS) @ HL-DT-STDVD+-RW GSA-H31L (SATA150, DVD+-RW, CD-RW, 2MB Cache, 32MB Flash) Optical Drive (F:) : N/A @ Optiarc DVD RW AD-7170S (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Dell 631xESB/6321ESB/3100 LPC Interface Controller LPC Legacy Controller 1 : SMSC EMC2700LPC Serial Port(s) : 5 Parallel Port(s) : 1 Disk Controller : Dell 631xESB/6321ESB/3100 Ultra ATA Storage Controller Disk Controller : Dell Enterprise Southbridge SATA cc=AHCI USB Controller 1 : Dell 631xESB/6321ESB/3100 Chipset USB Universal Host Controller #1 USB Controller 2 : Dell 631xESB/6321ESB/3100 Chipset USB Universal Host Controller #2 USB Controller 3 : Dell 631xESB/6321ESB/3100 Chipset USB Universal Host Controller #3 USB Controller 4 : Dell 631xESB/6321ESB/3100 Chipset USB Universal Host Controller #4 USB Controller 5 : Dell 631xESB/6321ESB/3100 Chipset USB2 Enhanced Host Controller FireWire/1394 Controller 1 : TI TSB82AA2 IEEE-1394b Link Layer Controller SMBus/i2c Controller 1 : Intel 5X00/7X00 XMB Ch 21-0 SMBus SMBus/i2c Controller 2 : Intel 5X00/7X00 XMB Ch 21-1 SMBus SMBus/i2c Controller 3 : Intel 5X00/7X00 XMB Ch 21-0 SMBus SMBus/i2c Controller 4 : Intel 5X00/7X00 XMB Ch 21-1 SMBus SMBus/i2c Controller 5 : Intel 5X00/7X00 XMB Ch 22-0 SMBus SMBus/i2c Controller 6 : Intel 5X00/7X00 XMB Ch 22-1 SMBus SMBus/i2c Controller 7 : Intel 5X00/7X00 XMB Ch 22-0 SMBus SMBus/i2c Controller 8 : Intel 5X00/7X00 XMB Ch 22-1 SMBus SMBus/i2c Controller 9 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Mobile Broadband Adapter : Option N.V. iCON 505 (GSM, 14.4Mbps) Power Management Mains (AC) Line Status : On-Line Battery No 1 : 100% Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 7.1 |
Pt 10+ liquid saffire 56+ saffire pro 40 masterclock? | Nightworker | Pro Tools 10 | 16 | 12-08-2012 10:29 PM |
New saffire pro 40 | S.TaylorRCC | Pro Tools 10 | 13 | 11-17-2011 01:49 AM |
Saffire le | gmsjay | Pro Tools 9 | 16 | 01-06-2011 04:56 AM |
saffire pro 40 vs liquid saffire 56 | AxeDye | Pro Tools 9 | 9 | 12-09-2010 05:19 PM |
PT 9 and Saffire 56 | Empireofthesun | Pro Tools 9 | 0 | 11-05-2010 03:32 PM |
