Old 01-04-2011, 10:06 AM
Raoul23 Raoul23 is offline
Exclamation Pro tools did not shut down correctly!
Hi everyone
ok here goes, I was recently working on a session which I've been using xpand alot. Now when I close the session it shuts down fine but when I try to load pro tools again it tells me pro tools did not shut down properly last time you need to restart windows.
I have trashed my prefs but it still happens this is the first prob I've had with pt9. While I was working in this session a few days ago before this problem existed. The session just locked up and closed out of the blue.
Has anyone else had this prob and know how to fix it
thanks
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 01-04-2011, 12:46 PM
mstucker mstucker is offline
Default Re: Pro tools did not shut down correctly!!!!!!!!
Just installed 9 and am getting the same issue. It was not happening on the initial install but has started after installing MOTU midi drivers and adding Pro Control.
Michael Stucker
Echo Park Studios
www.echopark.com
[email protected]
Old 01-04-2011, 12:54 PM
I haven't installed anything new this is why it's a bit strange do u think it's a bug
regards
Raoul Crane
Old 01-04-2011, 12:56 PM
PT9
Sweetwater Creation Staion HD (i7, ASUS P6T6ws, 6GB)
Win7 64bit enterprise
3-192
Sync IO
MOTU MTPAV
Michael Stucker
Echo Park Studios
www.echopark.com
[email protected]
Old 01-05-2011, 11:53 AM
PT9
3-192
Sync IO
MOTU MTPAV
Have you done a fresh install if so has this fixed the problem
thanks
Raoul Crane
Old 01-08-2011, 10:43 AM
I tried the 9.0.1 update, still same. Trash prefs, still same, unistall/reinstall still same. By the way this it an HD9 system I see you are running 003.
Michael Stucker
Echo Park Studios
www.echopark.com
[email protected]
Old 01-08-2011, 11:17 AM
Dism Dism is offline
Is the problem session specific? Or is it happening on all sessions? Tried Import Session Data... into a new session?
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 01-08-2011, 03:08 PM
TOM@METRO's Avatar
Is your Xpand2 library in the default location or on another drive?
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 01-08-2011, 03:28 PM
dterry dterry is offline
I've had this happen in a couple of sessions. The latest I attributed to something going awry with a plugin or a routing problem when I adapted a larger project to a smaller alt version, removing auxes, tracks, etc.
The ProTools.exe process wasn't shutting down, preventing launching ProTools again. Force quit would not work. Shutting down Win7 caused a BSOD/dump everytime.
I imported the tracks and full config from that session into a new session and all is well. Apparently it is a session corruption issue. I would import into a new session and see if that solves it.
Old 01-08-2011, 05:43 PM
Thanks Dism I'll try that first thing tomorrow I hope this is the case coz it's been driving me mad for days now. Justgotta reinstall 9.0.0 as I installed 9.0.1 and everything went belly up and nothing worked at all so I'll keep ya posted on this one thanks again for your advice
regards
Raoul Crane
PT9 don't shut down correctly! Milko71 Windows 0 10-31-2011 07:09 AM
pro tools 8, can we now see the waveforms correctly??? paulreed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 23 12-07-2008 01:47 PM
help!! pro tools le 7.3 shut down problems!! dmt2828 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-07-2007 05:14 PM
"ProTools did not shut down correctly" writethis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-07-2002 06:47 AM
Pro Tools won't shut down!! bigfrog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-06-2002 04:29 AM
