  #21
Old 08-23-2009, 11:19 AM
Will Russell's Avatar
Will Russell Will Russell is offline
Default Re: external talkback mic for D-Command
call tech support
Will Russell
Electric Wilburland Studio
https://linktr.ee/wilburland
M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock
M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS
  #22
Old 08-23-2009, 11:54 AM
macaholic macaholic is offline
Also make sure you turn down the level Pot on the internal mic when judging the noise of an external TB... Once I get the talent comfortable in their phones on initial setup, I usually just let the producer direct from the external and I just drive, making sure I have turned down my internal mic.
If I need to chime in, I'll just make sure my level is turned up...
  #23
Old 08-23-2009, 02:18 PM
zakco zakco is offline
Thank you!!
I just assumed that switching to external, bypassed the internal...never considered that the internal level would matter at that point. Problem solved!
-Z-
  #24
Old 07-11-2011, 12:00 PM
jds jds is offline
So I've done everything up to this point:
Your external mic ---> external pre amp in ---> external pre amp out --- external talkback mic input on the X Mon."
Now...
In protools- Where is the the talkback I/O- or is it set up in a different location?
  #25
Old 07-11-2011, 12:37 PM
Stig Eliassen's Avatar
You handle talkback in the Monitor section on the console. I've set talkback to Internal, and then Assign TB button on to Cue 1 in. You just set talkback to External, and it should work.
  #26
Old 07-12-2011, 05:03 AM
jds jds is offline
So I have everything set up as Chris prescribed for the external mic setup on the hardware side of the Xmon/D-Command. I also know the principle of setting up talkback via protools. I am just confused as to how to get the two to work with each other. Can anyone help? Is the talkback located in the I/O of protools?
D-Command Talkback via Cue Out CRefino ICON & C|24 2 05-22-2013 09:06 AM
Two Talkback Switches on D-Command nickmurphy ICON & C|24 2 05-07-2007 02:23 PM
D-Command Talkback Question PTGuy ICON & C|24 1 02-15-2006 10:11 PM
D-Command Int. Talkback PTGuy Pro Tools TDM Systems (Mac) 1 02-14-2006 03:09 PM
Command |8 Talkback Section? swimfan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-20-2004 08:04 PM
