Two Talkback Switches on D-Command
Anybody know if its possible to have Talkback trigger from a second location, just like you can on the ProControl....
many thanks nick |
Re: Two Talkback Switches on D-Command
D control has 2 footswitches ... D command has 1.
On D control you set the pref for what the switches do in the utility pages under preferences. I'm sure on D command it is the same thing, Under Utility / prefs : set the footswitch to Talkback. You can now toggle talkback on / off
Chris Lambrechts Applications Specialist- Live Sound |
the Single foot-switch input on the back of D-Command can actually accomadate 2 foot-switches. both capable of controlling playback, record and talkback independently from one another.
Wire them up as follows: Tip= Foot-switch 1 Ring= Foot-switch 2 Sleeve= Ground If you go into the utility mode (located in softkeys) you can assign each foot-switch as you please, you can also flip the polarity of the jack for different foot-switches... So technially D-Command gives you 3 different places where you can control talkback; the regualr talkback switch and the 2 foot-switch inputs. -lev |
D-Command Talkback via Cue Out | CRefino | ICON & C|24 | 2 | 05-22-2013 09:06 AM |
Talkback Switches | Dizzi45Z | Pro Tools TDM Systems (Mac) | 7 | 02-17-2010 07:02 PM |
Control 24 dim and talkback switches stuck on | Makin' Sausage Music | ICON & C|24 | 3 | 06-08-2009 06:26 AM |
D-Command Int. Talkback | PTGuy | Pro Tools TDM Systems (Mac) | 1 | 02-14-2006 03:09 PM |
Talkback switches? | CraigLearmont | ICON & C|24 | 4 | 10-28-2005 04:37 PM |
