Audio to monitors
To PT Users,
I have eight monitors connected via DB25 in's and out's of my MTRX Studio how would I check they are correctly phase aligned and routed to each pair. Regards |
Re: Audio to monitors
Here is how I would do it:
Place any 2 speakers side by side, connect any pair of outputs, Feed pink noise or tone to both. Any phase issue should be immediately apparent. If that pair is good, repeat as needed until you are confident that all speakers and cables are correct(though I suspect you may be worrying about nothing) A standard cable checker would be tough to use with a DB25 connection(but maybe someone builds an adapter for this purpose). A phase checker might also be used if you have access to one. Some audio analysis software measures for phase(I know SMARRT Live does, check on others such as SpectraFoo).
^^ the real way, with test tones. You never know if a cable or set of monitors was made or repaired badly.
In Pro Tools generate stereo pairs of sine and pink noise signals and have in and out of phase pairs. It's nice to "show" your ears a total out of phase signal pair when doing this. And if you do have a flipped connection they will sound perfectly in-phase. |
No Audio From Monitors | Kevinhogan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-14-2011 12:10 PM |
audio at 002, but not monitors or Command|8 | clampire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-13-2005 10:06 PM |
no audio to monitors on 001 | JOHN KEITH SR. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-08-2005 09:42 AM |
Audio monitors , | seared music | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-25-2003 02:48 PM |
M-audio BX5 and BX8 monitors. | pindebraende | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-15-2003 12:45 AM |
