Old 04-13-2018, 05:43 PM
Judkins401 Judkins401 is offline
Default Re: Eleven rack right output is louder than left
If the problem is the XLR output you can simplify stuff to a bare minimum and test by using the Eleven Rack playing back audio from a connected computer. Ideally using an audio signal generator in Pro Tools or a similar DAW.
The headphone output on the Eleven Rack mirror the main outputs so if you cannot hear a misbalance in the headphones that points to the analog output stage of the Eleven Rack or something after that.
If the inbalance is high you should also be able to measure that with a digital multimeter probing XLR outputs driven by a sine wave signal generator and confirm both the positive and negative side signals are mirrors of each other.... a common way of getting ~3dB loss on one side is to have one of a balanced pair broken/not working.
As for “sounding awful”, it’s impossible to guess what you are trying to do or exactly have set up. If you have solved the speaker balance issue then start simple with a guitar straight into the Eleven Rack and an amp sim in the rig only and monitoring via headphones or full range monitors are preferable to get started. Things will rarely sound great by just plugging a guitar into any amp sim, you have to spend time playing and learning.
If your Marshal has an FX loop you should start by going into that, and in all cases playing with gain staging is important.
Eleven Rack monitor only audible in left channel in Pro Tools Spara Eleven Rack 1 02-07-2015 03:27 PM
RIGHT louder than LEFT output!!!HELP!! [SOLVED] MallahStudio macOS 5 11-26-2013 05:17 PM
Left output of Digi 002 rack quieter than right. Illl0lll 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-27-2009 02:58 PM
Left channel output louder in Mbox 1, please help. pcmusicpro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-14-2008 09:40 AM
002 Rack Louder Right Output, Please HELP clod 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 09-29-2004 12:54 AM
