Old 11-13-2012, 05:45 AM
Gary Gould Gary Gould is offline
Thumbs up Is it ok to unplug my Mbox 2 when the S/PDIF LED light is flashing
Hello There
I have a Mbox 2 with Pro Tools 8.0.5 and I am using a Focusrite ISA One Digital Preamp plugged into to the S/PDIF input of my Mbox 2.
While I was recording some vocals using the S/PDIF digital input via a Focusrite ISA One digital preamp, I forgot to select the clock to S/PDIF in the Pro Tools Hardware window. But it seemed to record ok. I thought that it would not record at all if the clock was not set to S/PDIF in the Pro Tools Hardware window, while using the S/PDIF digital input.
Does it really matter if I don’t select the S/PDIF option in the Pro Tools Hardware window, for instance does it affect the quality of the recording.
Also I noticed that the S/PDIF green LED light indicator was flashing on and off when I had the S/PDIF option selected in the Pro Tools Hardware window but had no device connected to the Mbox2 S/PDIF input, or had my Focusrite Preamp still connected to the Mbox2 S/PDIF input but switched off.
Since I only record via the S/PDIF input, I thought it would be more convenient to leave the S/PDIF option in the Pro Tools Hardware window selected at all times.
My main concern is will this do any harm to the Mbox 2 or any other equipment.
Also I like to leave my computer on standby while not in use. In order to do this I must unplug the Mbox 2 from the USB socket first, because my computer will not switch to stand by while the Mbox 2 is still connected. Of course I click on the (Safely Remove Hardware) icon on the windows tool bar before doing this.
Is it safe to unplug the Mbox 2 from the
computer while the green S/PDIF LED light on the front of the Mbox 2 is flashing on and off.
Thank you for reading this thread.
Gary Gould
Mbox Pro Blue flashing light. New to Pro Tools EdwardxP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-29-2013 04:23 PM
Is it ok to unplug my Mbox 2 when the S/PDIF LED light is flashing Gary Gould 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-24-2012 07:51 AM
MBOX 3 Not Working Flashing Power Light Imran5000 General Discussion 1 10-03-2011 12:22 PM
MBox Power light flashing! ym2149 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-30-2010 12:40 PM
FLASHING S/PDIF LED LIGHT ON MBOX 2 PRP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-24-2007 08:05 PM
