Nero won\'t burn WAVs
Why can't I burn a WAV bounce? (When I bounce to AIFF it works).
Asus P5K Deluxe Pentium Q9550 @ 3.4 ghz Corsair 1066 RAM www.guyfi.com www.flystudiosmilwaukee.com |
Re: Nero won\'t burn WAVs
Originally posted by guy.fi:
You apparently have to open the wav file in another editor(like cooleditpro, et.al.), resave it as a wav, then burn it in Nero. Good Luck Mitch |
do u have the lates update on nero..??
brian uller
Brian Uller Denmark |
I used to have this problem too. Only the most recent versions of Nero will work with PT .WAV files. I'm not sure exactly where the cut-off is but I'm using 5.5 and it works fine. The problem has something to do with PT putting a tag into the bounced-to-disk files that older versions of Nero didn't like. There have been a few threads on this before, do a search of the DUC and I'm sure you'll find some more exact answers.
James |
As far as I know, Nero will not burn the PT wavs. In order for my tracks to burn, I bounce to disc, 16b, stereo interleave etc... then open the file up in soundforge, do what you need to do in soundforge and save. Once the file is saved in soundforge, it is in a format that will burn to disc, and is playable on any system. There are more technical reasons having to do with the types of waves that PT utilizes when bouncing to disc that are different than the usual wave files we are all used to working with.
Ad astra per aspera... |
MusicMatch Jukebox Plus works every time - I had the same problem with Nero (old version - newer versions should work )
What a coincidence. I spent the whole weekend banging my head over this one. Now I know.
I'm using XP and tried to burn a CD from there (after trying a million times with nero). It still didn't like the protools WAV files. Couldn't get it to work. Should I just stop using WAV files? THe other thing...I burned some MP3's onto a cd from my old computer as an audio disk and tried to load them into protools. When I tried to transfer them it said protools couldn't recognize them. Actually I have been unable to get any files into protools off CD's including off store bought CD's. But I have burned CDs fine using NERO. And I have imported WAV files into Protools, but only ones that I downloaded off the net to this computer. Any help would be ever so greatly appreciated, I'm pulling my hair out. Paul [img]images/icons/confused.gif[/img] |
guy.fi- it's a known bug that nero does not read pt .wav files. i havent tried the new versions of nero, but i am told this bug has been fixed.
+CORPORATE WHORE+ www.8mmOverdose.com www.Tondra.com www.UnderworldEvents.com www.JagerMusic.com www.MonsterEnergy.com |
Alex T. has the answer.. this is a well known problem with versions of NERO before 5.5.9
get the newest NERO and it works fine |
Stupid question, but is there any way to avoid paying for it? I got a copy with my burner. Maybe I should buy a cheap burner, since I need one anyway...
Nero 5.5.5.6 won't burn wav files from LE 6.4.. | dubs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-02-2004 10:12 AM |
Session Archiving - Nero won't burn disc | blizzard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-25-2003 11:23 AM |
Nero can now burn wav's from ptle!!! | Bastiaan | Digidesign Hardware & Software | 3 | 09-09-2002 06:36 PM |
Nero can now burn wav's from ptle!!! | Bastiaan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-08-2002 01:20 PM |
Trouble Importing Pro Tools Wavs to Nero | Cam B | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 09-05-2001 03:51 AM |
