Channel Strips & Pro Tools 10
What's the difference between using a channel strip on a specific channel or an EQ & Compressor on that specific channel ??
Regards, |
Re: Channel Strips & Pro Tools 10
The main advantage is not taking up as much insert slots. This is not as much of an issue since PT expanded to 10 inserts from 5.
Other than that, it's identical. For example, if you used the Waves Renasscance channel, which includes the R. compressor and R. EQ, it would be no different in terms of CPU processing or sound quality vs, using those individual plugins. However, as you know, some channel strips, like the Waves SSL, or Avid Channel Strip, are only available as channel strips, and do not have individual versions (though you can turn off what you don't need). |
Most channel strip plugs include a gate - plus EQ and comp.
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
Nts7 is mostly right, except that the channel strips that comes with pro tools is based on the system 5 channel strips. There's no equivalence in what PT has as individual plugins, and it's also a lot less CPU intensive than if you had the same amount of individual plugins instantiated.
Cheers .... One More Question .... Let's talk drums ... (synths, basslines aside ...) which is better ?? knowing it's a totally subjective question .....
compressing the kick, the snare, each one alone or putting a compressor on an aux drum bus .... same goes for EQs .... i am a newbie in mastering ... |
Thanks guys ... but I guess that's why i inserted the word "sujective" when i was asking the question .... Say we are talking about dance tracks ... a normal kick and snare ... 808 or 909 kits ... any good .. i mean great tutorials ?
I usually put a compressor on each individual drum/mic to get the sound I want. Unless you are totally squashing each drum, each will usually require different compressor settings. I usually avoid or only slightly compress cymbals to maintain a nice, natural decay. Discerning mic placement on the drum kit has a very big impact on the quality of your tracks.
Hope this helps, Greg
Protools PC, i9 10990, Gigabyte X299 mobo, 64 GB ram, EVGA Nvidea GT 720 TI video card, Win 10 Pro, PT Ultimate (Native) 2024.3.1, HD Omni, HD I/O 16x16 . |
But, there's no fast way to learn these things. You see, it's about learning the trade, and training your ears. Compress and eq every track separately, or compress and eq only the drum bus? There's no right answer here, other than you doing what the song needs. Tutorials can help you with the technical side of things, and probably inspire you, but you have to put in the extra effort. Experiment, experiment, experiment.
Control 24 channel strips | dickybabes | ICON & C|24 | 0 | 02-07-2009 06:34 AM |
480 Waves SSL Channel Strips | tribase | Pro Tools TDM Systems (Mac) | 20 | 12-28-2006 09:35 PM |
Channel Strips | WaDa TanK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-17-2005 08:19 AM |
Question about channel strips | Sennheiser | Digidesign Hardware & Software | 6 | 07-30-2002 08:23 PM |
Mic Preamps/Channel strips | poppy | Pro Tools TDM Systems (Mac) | 6 | 05-07-2002 12:10 AM |
