Analog patchbay used as a split to Monitors & FOH
The title should explain what my question is.
We have an old split that has problems. I would like to bypass the split and use analog patchbays to feed the Monitor stage rack and the FOH stage rack. Signal path would be as follows: Stage input -> analog patchbay -> both Mon & FOH stage racks Has anyone tried this before? Would you advise against it? I'm listening. |
Re: Analog patchbay used as a split to Monitors & FOH
As long as it is wired properly, I do not see it as being a problem.
Ken Miller, Jr. Audio Engineer Southside Baptist Church | Warner Robins, GA | VENUE Profile 96X64 with MADI Option | ProTools 7.4.2 HD3 Accel PCI | ProTools 10 Native | MacBook Pro 17" OS 10.7.1 2.3GHz Intel Core i7 8GB Ram | Mbox 2 Pro | Mbox 3 Pro | Motu 896mk3 Hybrid |
https://www.thirdeyerecording.com/ |
I can see a problem that I would be interested to hear from those who know more than me.
One of the purposes of a split is to isolate phantom power from the console supplying the power so that it doesn't damage the other console. On the same note, it would absorb and not allow phantom from the isolated console to send and not damage the other console. I know there are certain consoles which are perfectly fine taking a channel input which has phantom applied from another source, just not sure if Venue is one of them. Like I said, I am sure those who know more than me would have much to say about this and it will be interesting to hear other opinions. |
The patchbays are TRS.
My thoughts on the phantom power is that each stage rack would receive it from one of the consoles. Now with the system this way only one console would supply phantom. Kinda counting on this working this way. Very similar to the Digico consoles. Master and slave. Im not sure what would happen if both sent phantom to a single channel. Anyone else have any ideas on this? Im listening. |
I would use a snake with a passive splitter(no transformers) and turn phantom power OFF on one of the consoles. You may still want/need ground lifts on one side of the split(pin 1 disconnect) but this must be done on the side to the console that DOES NOT provide phantom power(lifting pin 1 will defeat phantom from that desk). A patch bay by itself does not accomplish splitting anyway.
I know a patchbay does not accomplish splitting but if you wire it with two outputs per single input I believe it will do the same thing as a Y cable. The reason for the patchbay is we will have inputs in multiple zones on stage, more onstage inputs than stage rack inputs. This will give us the ability to place items anywhere on stage and patch them in any of the stage rack inputs. |
Also, with TRS be sure to avtivate 48v only AFTER the patching is done. While plugging in a TRS; the tip, ring and sleeve will all have a moments contact with phantom.
Potential mic hazard. |
Really IMO, you should use a splitter. Passive is ok, transformer is better. The patchbay is just another place for something to go wrong. Troubleshooting in live sound can be hard enough and I don't see any reason to make it worse with a patchbay, especially with software patching on digital consoles.
I inadvertently kept messing up Millenia Media HV3 preamps using a TRS patchbay and phantom..... It's bad.
Northern California Audio Rentals |
monitors pop when switching analog insert | tfricilone | Pro Tools TDM Systems (Mac) | 0 | 11-04-2007 12:06 PM |
Digital or analog monitors...? | Ralph K | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-18-2004 07:42 AM |
Analog Patchbay | Dennis D | ICON & C|24 | 0 | 04-23-2002 06:09 PM |
TwinView w/ Digital and Analog Monitors? | fporter | Pro Tools TDM Systems (Mac) | 0 | 10-18-2001 11:25 PM |
2 MONITORS & 16 ANALOG I/O | JUHANA | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-30-2000 07:52 AM |
