Old 01-31-2009, 11:04 AM
crizdee's Avatar
crizdee crizdee is offline
Default Updating older chassis with magma board set PE6NE (PE6R4)
Anyone done the update of an older chassis with one of the Magma board sets.. http://www.magma.com/products/board-sets/
$1500 gets the pe6ne turning your old chassis into the latest PE6R4.
I'm thinking of doing this? any problems.
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-31-2009, 12:35 PM
HearInc HearInc is offline
Default Re: Updating older chassis with magma board set PE6NE (PE6R4)
Originally Posted by crizdee View Post
Chris
I looked at that, and called Magma, but my case is so old that it would require a new back of the box and redrilling the holes, and a bigger power supply. So, not worth it for me. If your old one is relatively recent, you can probably do it without much trouble. They'll tell you at Magma to be sure you've got a 400W power supply, but don't buy theirs... it's like $250... I saw them for $35 elsewhere.
Brian Steckler, Producer
Old 01-31-2009, 01:39 PM
Galahad Galahad is offline
I've been wondering about this myself, from what I can gather you can put one of these in an ATX case (it doesn't have to be a Magma case). I was thinking of getting either the PCI4NE or the PE6NE, which would be a much cheaper solution than buying a ready made magma system. For a 4 slot I figure it would be $799 for the board, $100 for the case and $50 for a PS. I just would like to know if anyone has one working (4 or 6 slot).
Cheers
Alan
Old 01-31-2009, 01:51 PM
Cheers
Alan
As I understand it, the only one that's qualified to work is the one in this box. Here's the backplane on it's own. I guess for HD you need the Low Latency version. I've read about guys that have other ones working, but it sounds like there are track limitations that are under normal Digi specs.
Old 02-08-2009, 11:36 AM
Lizardpoint Lizardpoint is offline
Hi Chris,
I've got the Digi Ethernet expansion currently but ordered the Magma Board set from the US (When the exchange rate was alot better than it is now)
I got an old Magma chassis (Hopefully the Digi 6 slot chassis will work with PT8 even if its not qualified and I can sell it to get some money back - It cost me almost £2K less than 2 years ago !!!!)
I stripped out the board from the old magma chassis and hit my first of many problems:
1. the old PSU is AT while the new board requires an ATX psu.
2. Only 3 of the 8 backplane mounting holes line up, so you'll have to get busy with a drill to put the extra support pillars in the right place.
3. The rear panel of the old chassiswill need to be cut away as the super high speed connector fouls against it and the backplane wont fit.
I've put it all in the "Too difficult pile" for the time being.
I suspect that a standard ATX PC case might be a better option so will look into that next
And even if I do get it working and complete the planned update to Leopard and PT8 there's more misert in store...
Rumours of losing a processor with RTAS plugins,
Some of my fave plugins not leopard and/or PT8 friendly
Oh well, I suppose it keeps me off the streets....
I'll let you know ho I get on.
Lizardpoint
Old 02-08-2009, 01:16 PM
crizdee's Avatar
Originally Posted by Lizardpoint View Post
Hi Chris,
Lizardpoint
I have just installed PT8 on a MacPro 8-core Harpertown and the Digi expansion HD/6 ethernet chassis. core/accel/accel/process
Its a bit too early to give an exact report of how things are running! But..
At 96K i can only get 96 voices (I though an expansion chassis was needed to get bigger track counts? well according to the expanded systems guide
RTAS seems only a bit better than my G5 dual 2 gig
Autotune EVO RTAS is crash city AT4 RTAS on PPC PT8 never crashed and i could get about 40
Only loss of plugins so far for me... SSL LMC. maybe Trilogy but i'm going to try their intel wrapper?
Cost of upgrading plugs about £700 for me Autotune/Mach Five/ URS MP5/Sonnox/Soundtoys
If you want to sell your Magma board set let me know
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-08-2009, 02:29 PM
Mixchump Mixchump is offline
Hi There,
I ordered a PE6-NE board upgrade set and installed it into an older chassis that also had the incorrect PSU. I just grabbed a nice silent PSU from the local computer hardware supplier, and everything was fine after that.
I did have to drill a few holes in the case to re-locate some standoffs, and of course took the tin-snips to the back of the case to make room for the iPass connector... Seriously no big deal.
If you have a newer chassis, or any ATX computer case, you're in business.
So far, it's been working flawlessly for me, and no performance hits that I can detect. Even though this board is much lower-latency than my old Digidesign 64-Bit chassis (PCI to PCI), I've left the hardware buffer at 1024 just because it doesn't matter to me either way...
TONS of RTAS horsepower with the Harpertown 8-core, and things are much less crash-prone than the G5 Dual 2G ever was.
Just for clarification here. The motherboard inside a PE6-R4 chassis IS a PE6-NE. The only difference is that you're not getting the case and PSU. That's it. No magic.
Anyhow, working great here. EVO is solid here. Hmmmm. I have to say, I do shy away from the TDM version because I feel like I can hear a lot more tuning artefacts than the RTAS version...
As far as voice count goes, I always thought that 96 was the max at 88.2/96k, and 192 was the max at 44.1/48k. I've got HD6 running here. HD-Core, and 5 Accell cards. All slots used. ROCKS!
Anyhow, that's what I can tell you at this point!
Cheers, eh?
Old 09-03-2010, 01:16 AM
Studiocube Studiocube is offline
I'm about to build my expansion rack with a PE6NE kit.
Which PSU should i buy to manage the PE6ne motherboard ? I can't find atx psu with 2 atx 20 pin connectors ...
If someone could advise me would be cool !
Old 09-03-2010, 02:20 AM
crizdee's Avatar
Originally Posted by Studiocube View Post
You only have to use one of the atx power connections on the board!
On the pe6r4 the atx socket nearest to the back of the chassis is NOT used.
Read this thread it has all you need to know in it...
http://duc.digidesign.com/showthread...ht=magma+pe6r4
Chris
Producer, Engineer,
www.ukmastering.com
Old 09-03-2010, 02:52 AM
summit01 summit01 is offline
I did the upgrade... the problem is the back panel- there are no holes. Either you have to drill them or glue the back panel. Same with the power supply. Btw. you have to buy an extra 450W supply, since the old supply is 350W, I think. I fried my old one...
WTB: Magma PE6R4 Expansion Chassis MichaelLewisMusic Buy & Sell 8 07-20-2012 09:57 AM
Magma Pe6r4-i Epansion Chassis tvent Buy & Sell 0 06-09-2012 11:41 AM
Magma PE6R4 chassis and motherboards PT9 Raoul23 Pro Tools 9 0 06-30-2011 06:07 AM
Anyone Run PT 8 TDM with the Magma PE6R4 Expansion Chassis kd_special Post - Surround - Video 4 09-23-2010 06:26 PM
Magma PE6R4 Chassis Fans TimNielsen Pro Tools TDM Systems (Mac) 5 10-24-2008 08:30 AM
