Playing Virtual Instruments
I am new to using Pro Tools and I have a question for anyone who can answer this...how can I get my Roland Fantom X6 to play the virtual instruments in Pro Tools?
Re: Playing Virtual Instruments
1. Run a MIDI cable from the Fantom to a MIDI In on your PT interface
2. Make a new device for it in Setup/MIDI/MIDI Studio 3. Make an Instrument track 4. Place a virtual inst plug-in in one of the inserts (customarily the first insert) 5. Make sure the track is highlighted or in record
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
Thanks...I will try that later today
Should the MIDI cable from the Fantom be in MIDI Out?
Regarding the hookup part:
Fairly simple, just install the fantom midi driver into your computer and hook up your Fantom X6 to the computer via USB. This is how my Fantom X8 works.... |
Out the phantom into the ???...dnt know which interface u have...& actually u dont necessarily have to setup a new device in Midi setup unless u want to & when u create the instrument track just make sure that u have the "Instrument" view on so u can see it @ the top of the mix window & that the top says "ALL" & the next tab shows the name of the VI ur using...also in "options" make "MIDI THRU" is checked...
I have my Fantom X6 connected via usb midi and Pro Tools 8 midi setup sees the Fantom. So are the instructions from daeron80..correct? Are there any settings I need to do on the Fantom...ML_Music?
Sorry, didn't know you already had it hooked up to the computer. Was going for dead simple. I'll let someone who has a USB connected MIDI controller take it from here.
Thanks All, I got it to work. I really appreciated the help.
And now the fun begins!!
Virtual Instruments playing AHEAD of the beat | ansanity | macOS | 14 | 04-12-2022 12:47 AM |
Some virtual instruments not playing back | Eric.Yeung | Windows | 3 | 06-08-2012 03:01 AM |
MIDI track playing several Virtual instruments | d2pc | Pro Tools 9 | 1 | 09-05-2011 03:46 AM |
Playing Virtual Instruments Problem | jaxsun23 | Virtual Instruments | 0 | 11-04-2009 12:10 PM |
playing multiple virtual instruments in a session | explorationx | Virtual Instruments | 4 | 03-15-2008 06:49 PM |
