trouble with .wavs
Hey guys,
I'm in a fairly frustrating situation here. Whenever I bounce a track in Pro Tools 6.3 to .wav, it apparently cannot be worked with in any audio workstation aside from Pro Tools itself. I'm bouncing as the following: File Type: BWF (.WAV) Format: Stereo interleaved Resolution: 24 Sample Rate: 44100 Convert After Bounce The problem is that my producer/mixing engineer works in Soundforge, and is unable to import these files into his program of choice. However, the problem is not on his end. As a test, I tried to import the audio myself into Cakewalk Sonar, and I couldn't get the files to work there either. It just says the "audio format is incompatible". However, these same files still work like a charm in Pro Tools. So it basically boils down to this: How do I simply bounce an all-purpose .wav file from Pro Tools? Thanks! |
Re: trouble with .wavs
you must put the dither plugin on your master fader and set it for 16 bits!Make sure the dither is first on the master fader also .
Davec 1 results,32+68 at 1024 buffer,32+ 41 at 128 buffer both 24 bit |
Check to see what the bitdepth and samplerate of the cakewalk and soundforge sessions are and bounce your files accordingly.
Cavell Studios |
Hey gira29 ,
Today is a holiday here in Canada, so my advice might be slightly off, due to consumption of over sized beverages... However.. Quote:
We (PC users ) never had a 6.3....so, make sure to also enforce the Mac><PC compatibility mode ! Soundforge should easily open 24bit BWF's. WaveLab does... But, if no go..try AIFF. good luck, cheers,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
I can open stereo interleaved 24 bit 44.1kHz created with Pro Tools in Sound Forge (and any other well written app which supports that resolution) just fine... which version of Sound Forge is he running?
Why don't you BTD a small file and email it to me.. or check it out with my Header Investigator. Rail
.aif files to .wavs? | digifriend | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-30-2010 11:19 AM |
Plays imported wavs, records new wavs, BUT WON'T PLAY NEWLY RECORDED WAVs | cmoseman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-02-2008 10:20 AM |
Need a couple of WAVs... | xeetstreet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-04-2004 03:04 PM |
Trouble Importing Pro Tools Wavs to Nero | Cam B | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 09-05-2001 03:51 AM |
help with wavs please!!!! | Stashcom | Digidesign Hardware & Software | 1 | 02-14-2001 12:49 AM |
