Old 06-20-2021, 12:41 PM
Default Re: Multiple copies of plugins - delete?
I also use mac color labels on plugins, like; one color for Avid basic plugs, one for 3rd party safe and tested, and so on. Makes it easier to spot newly installed, updated and so on.
Hadn't thought about this - thanks for the tickler.
Old 06-20-2021, 04:32 PM
Sardi Sardi is online now
Default Multiple copies of plugins - delete?
I used to do that too until I realised that moving plugins into sub folders within the plugins folder didn’t affect them loading in PT.
Now I I essentially do what you do, but instead use folders. Like you mentioned, very useful having them organised to identify them.
Old 06-21-2021, 08:08 PM
basslik's Avatar
basslik basslik is offline
How do I navigate to that page please. Library ?
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
Old 06-21-2021, 08:12 PM
basslik's Avatar
Originally Posted by albee1952 View Post
Not sure I understand, but most plugins can just be removed from the Plugins folder. If that doesn't work, I would uninstall the entire package that included the freebie, then re-install just the freebie. If none of this helps, what plugins are you having trouble with?
Wrapped Plugins, form blackrooster audio.
Essentially I don't know where to get to the proper folder.
Old 06-21-2021, 10:31 PM
JFreak JFreak is online now
I used to organise plugins myself in the TDM days when updates were few, but now that it seems I need to update something every week I have not bothered. Just let them be where they are installed in the first place. Though I would like it if all plugin vendors would add their plugins to a COMPANYNAME folder.
But back to the point, removing plugin file does no harm to the system. It is just the same as moving it to the unused folder.
Old 06-22-2021, 02:06 AM
Wrapped plugins? What wrapper are you using? FXPansion stopped supporting their app a loooooong time ago.
If you mean a hosting plugin like Patchwork, that’s not wrapping anything. It’s merely hosting the VST/AU component within the plugin itself.
If you want to remove those, navigate to the VST and AU folders and delete them from there.
AU
Library/Audio/Plug-Ins/Components/
VST
Library/Audio/Plug-Ins/VST/
Old 06-22-2021, 04:03 AM
Navigate to what page?
If you're talking about the folder where your PT aax plugins are stored it's MacHD/Library/Apoplication Support/Avid/Audio in there you will find two folders - one named 'Plug-Ins' and the other named Plug-Ins Unused).
Old 06-23-2021, 10:38 PM
basslik's Avatar
Thank you all. Yeah it's in a wrapped drop down menu. Never seen that before. I just went ahead and reinstalled everything cause I did remove all the plugins, but it won't disappear in the drop down menu.
Does PT2020 run VST & VST3 ?
Old 06-23-2021, 10:51 PM
No.
Post a screenshot of these ‘wrapped’ plugins. I’m not aware of any wrapper for AAX.
Old 06-24-2021, 04:11 AM
Originally Posted by Sardi View Post
No.
What's a wrapped drop down menu?
PT can run vst2 & vst3 plugins but you need a host like Blue Cat Patchwork or VE Pro.
HTML code is On
Multiple copies of an OMF while copying session Unskirmisher Post - Surround - Video 2 08-07-2016 12:32 PM
Editing MIDI across multiple copies babygoboom Tips & Tricks 3 12-02-2015 06:23 AM
Multiple computers = multiple copies? Earfatigue Pro Tools 10 8 03-07-2012 05:47 PM
Using multiple copies of OS X copywell Pro Tools TDM Systems (Mac) 1 01-04-2004 01:11 PM
OMS does not allow multiple copies... c_hebb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-08-2002 07:04 PM
