Is it possible...
To use a 3rd party software program w/ my digi 001 such as Cakewalk 9.0 or Cool Edit so that I can perform some "mastering" techniques to my mixdown .wav file? I wouldn't be doing any recording within these programs, just alterations to the .wav file. I'm running a PC w/ windows ME. Is that at all possible using the digi 001 (and not another sound card), and would I need to get a certain driver to make it happen? The only driver I have installed is the one which came with the CD, and I haven't installed any updates or other digi001 drivers because my system has been stable and I didn't want to compromise that. Thank you!
Gabe Abadilla San Diego, CA |
Re: Is it possible...
Any ASIO Supported application will work as there are 001 ASIO Drivers
Pro Tools & Logic Programmer, Engineer, Consulting, Education |
It is my understanding that, according to a search on this forum, only Logic Audio will allow you to tap into all the channels that the 001 supports, otherwise you're limited to just channels 1 and 2.
Actually, ASIO is only supported on the Mac. This is a Windows forum. However, you can use your 001 with the standard windows MME drivers with most audio apps, and it works great. So no, you don't need another card.
If you are just talking about a 2 track wav. file, I use Sound Forge with the 001, and it works just fine.....
www.dawbox.com |
