Old 04-21-2020, 04:15 PM
ProTools4's Avatar
ProTools4 ProTools4 is offline
Default ?possible? Vintage Mix+ PCI TDM cards in 2020
opened ended question
is there any way to build a modern / modernish machine in 2020 for vintage Mix Core / MixFarm / SampleCell2 cards?
NotoriouSS Tad
PT 2023 HDX3 maxed system 7,1 Rack Mac Pro
PT 5.1.3 OS9 maxed system G4 1.33
Old 04-24-2020, 08:11 AM
Default Re: ?possible? Vintage Mix+ PCI TDM cards in 2020
Gonna be near impossible to find a modern motherboard with PCI slots
Old 04-25-2020, 12:54 AM
ProTools4's Avatar
Have several local stores that have vintage to modern stuff
or we could think out of the box
https://www.startech.com/Cards-Adapt...-Card~PEX1PCI1
https://www.startech.com/Cards-Adapt...n-Bay~PEX2PCI4
NotoriouSS Tad
Old 04-06-2021, 09:22 AM
Suad Cokljat's Avatar
Suad Cokljat Suad Cokljat is offline
Hi. What you need is Industrial Mainboard. There is a good choice from various manufacturers. All are based on modern chipsets using onboard pci-e to pci bridge. Some models feature gen7+ Intel CPU support and even 6 x 33MHz PCI slots + few PCI-e slots. Some models feature even ISA slots together with PCI and PCI-e.
Take a look at MSI IPC:
https://ipc.msi.com/products_list/In...otherboard/ATX
Cheers!
Suad
Old 04-06-2021, 11:34 AM
JFreak JFreak is online now
Also remember the last PT version that supports MIX cards was 6.4.1 which requires OSX Panther or Windows XP -- be sure your hardware is supported on those ancient OS, otherwise you are out of luck even if you got leds blinking.
Old 04-07-2021, 08:17 AM
I just came back to warn about potential legacy OS and new mainboard compatibility issue and see that you had already explained Intel Gen 10 and newer most likely have isuse for Windows 7 compatibility let alone with Windows XP...
Cheers!
S
Old 04-11-2021, 08:43 AM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Yes, only way to use these is in a Mac G4 or older, or with an older windows machine. OS, plug-in, and 3rd party software compatibility is very finicky, as these systems are almost 25 year old tech. Iirc support was dropped in 2004.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 04-11-2021, 09:21 AM
How is your Satchmo card still working?
Old 04-11-2021, 09:54 AM
Still going. Just used it to run a track through sound blender from my modern pro tools rig
- John
Old 07-09-2021, 12:43 AM
Sugarnutz Sugarnutz is offline
I used to have a 6.4.1 license which was a code, lost it and no way of retrieving it since the Digidesign Store no longer exists. I had a 5.3.1 and a 6.x LE license too and just found my old Audiomedia III card a few months back when cleaning a storage.
Gigabyte z390 Designare
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
Win 10 Pro
15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM
512 Gb Flash Drive - OS X 10.14.6
2020.3 is out innesireinar Pro Tools 2020 114 04-09-2020 08:55 AM
Pro Tools (2020.3) on MacBook Air 2020 compatibility pellekuipers Pro Tools 2020 1 04-04-2020 08:01 AM
Mac OS 10.12.6 & PT 2020.3 Shefi Pro Tools 2020 2 03-31-2020 02:18 PM
New Avid Link 2020.1 - launched today 1/16/2020 marianna Licensing & Accounts 8 01-16-2020 11:43 PM
How many vintage farm cards can I have in a Bit 3? ProTooler Pro Tools TDM Systems (Mac) 1 02-01-2003 01:30 PM
