Master Bus + Midi delay compensation
Hello all,
I am experiencing a problem with Pro Tools Ultimate latest. I have SoundID room corrector on the master bus. That's the only plugin I have in the master bus chain. When recording an instrument channel that has no plugins other than the instrument, I am experiencing severe delays in midi in the recording - the recording is completely off in terms of timing. I wonder if other people are experiencing this, and what is the remedy. Thank you |
Re: Master Bus + Midi delay compensation
Turn off delay compensation on the track with a VI on it. It's part of the nasty delay compensation bug for everything MIDI. In the sticky at this forum "PT-263943 .
However, if you use this workaround: don't use plugins on the track with a VI with significant sample delay, otherwise things will go south again regarding timing:)
Apple MacBook Pro M2 Max, 96GB ram | Pro Tools HDX | Avid MTRX | Pro Tools Ultimate 2023.12 | macOS 13.6.3 |
Also, make sure that if you are tracking things with SoundID Enabled on your master bus, make sure the filter is set to "zero latency". In the other modes, you will have some latency and PT will not account for it.
Thanks Robert and Chris,
Just to understand, this problem has been in Pro Tools since ver 12? I find it impossible to believe. |
Delay Compensation on Master? | JazzyJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-19-2011 12:10 PM |
Delay Compensation + Master Track | twix | Pro Tools 9 | 10 | 08-27-2011 03:52 PM |
Bypass Delay Compensation on Master Bus? | Dizzi45Z | Pro Tools TDM Systems (Mac) | 6 | 05-16-2008 09:15 PM |
Can you disable Delay Compensation on Master? | AINSLIE | Pro Tools TDM Systems (Mac) | 7 | 02-15-2008 09:56 AM |
Delay Compensation on Master Fader | musicnutt2000 | Pro Tools TDM Systems (Mac) | 1 | 09-12-2006 04:08 AM |
