#21
Re: Unable to record audio
Hello. I know that I sad that I wanted to close this topic but I've done the following : I logged in on internal mac os hdd drive and run the application but when I wanted to record audio I got the same disk allocation error.I even unplugged my external ssd(mac os) but got the same error. Can this be a bug?
#22
No it won't be a bug. It will be something you are doing.
None of this makes a lot of sense. To start with: if the internal HDD is too slow to boot/run from then it's likely too slow to record to. You likely should be recording to the external SSD you have booted from. Either way start by trying to do that, creating and saving a new empty session to your Documents folder on that external drive (which should be ~/Documents aka /Users/<your account>/Documents). I do a lot of work with my MacBook Pro booted from an external M.2 PCIe SSD and recoding to that SSD or to other M.2 SSD, sometimes recording to the internal SSD on the Mac Book Pro. All this will work and is usable if you set stuff up properly. Any problem is likely some filesystem or Pro Tools volume permission problem. We cannot guess, you keep dribbling information out here. If you want help you need to provide clear information. Ideally in one post, what filesystem types on all the different drives, what exact make/model drives, where exactly you are recording to, what ownership permissions of that drive/folder is, what is the uid and gid of your user account, etc. etc. We are three pages in on this thread and it's not even clear mac you have and stuff you are saying and your DUC system profile info don't agree. If you want to keep goign here start over by reading "Help Us Help You" up the top of each DUC web page and provide one very detailed post about your setup, exact versions of everything, exactly what you are doing, other stuff asked for etc. Last edited by Darryl Ramm; 06-10-2023 at 11:00 PM. |
#23
Problem fixed.
Finally it can record on another external ssd.I tweaked around the permissions. Thanks |
#24
Great you got going. So it was UNIX file systems permissions?
(That can happen a lot when migrating systems/accounts). |
#25
It was actually the disk allocation. It seems to be an issue how the drive was formatted . so on the other external ssd drive can be recorded audio.
#26
You can erase and reformat the errant disc in Disk Utility inside the Mac "Utility" application folder
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4 Enjoy the Journey.... Kev... |
Unable to record Kurzweil audio engine in PT11 | insightsono | macOS | 1 | 04-27-2018 10:16 PM |
Unable to Record (digitize) a Regular Midi Track to an Audio Track | JuicyMusic | macOS | 9 | 02-27-2013 08:52 AM |
Unable to record live audio | Phresh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 05-29-2011 02:27 PM |
Unable to Record BFD Audio | paxfax | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-19-2009 02:49 AM |
unable to make my FW drive "audio record volume" | andycopeman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-18-2008 08:11 AM |
