Old 03-14-2012, 08:59 AM
Ty Ford's Avatar
Ty Ford Ty Ford is offline
Default Errors in Slip mode for groups
After I group two tracks and then select them to slip, I see the selection outline around them, but when I move them only one track slips....most of the time.
I think this is a bug.
What to do?
Ty Ford
Old 03-14-2012, 09:16 AM
cneal92's Avatar
cneal92 cneal92 is offline
Default Re: Errors in Slip mode for groups
This happens if the regions on the tracks do not have the same start/end time. Two options, 1) grab the longest track to trim or 2) highlight an area on all tracks at the beginning/end and delete so they all start/end at the same location. Now your trim tool will work on any of the tracks.
Chris Neal :: South Plains College
.: Program Coordinator & Asst. Professor in Sound Technology
.: [email protected]
.: Pro Tools Certified Instructor
.: Pro Tools Expert Certified in Music
Old 03-14-2012, 09:23 AM
dankin dankin is offline
Usually when that happens its because the regions are different lengths or they have different starting points. I've seen that off and on for the as long as I've been using PT.
Old 03-14-2012, 05:07 PM
Ty Ford's Avatar
and yet, this evening, while NOT trying to use groups, selecting multiple tracks and slipping worked fine.
The "known issues" in PT 10.0.1 are very for boding. They seem to outweigh the present problems in 10.0.0. Toss the code writer a few more buck to clean that mess up, will ya!
Regards,
Ty Ford
gridlines in slip mode flesstone macOS 5 02-09-2019 02:27 AM
SLIP mode on Pro Tools SE beatrizfons10 Pro Tools SE and Essential (Win) 6 12-17-2011 09:38 AM
Grid Lines in Slip Mode 9.0.5? anackman macOS 3 09-15-2011 03:24 PM
Slip mode but no overlap dagamba 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-14-2010 02:56 AM
Grid mode, shuffle mode, spot mode and slip mode. RogTaylor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-24-2010 10:30 AM
