Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Sync X & SYNC HD
Old 08-29-2023, 02:20 AM
captainvimmes captainvimmes is offline
Default Different VSO for different FPS?
Hey,
I've just started working on some 23.98 content and I noticed that the sync just didn't seem right. I got my synch-check out and it was about by just under 40ms (~1frame), I switched it back to 25fps and then 24 fps and it was back in sync. Is this a known thing; 23.98 requires a different sync offset to 24/25?
Setup: Mac Pro 2019, PT 2022.12, Sync X, HDX 2, MTRX, Blackmagic Card
Thanks in advance!
Old 08-29-2023, 06:15 AM
its2loud its2loud is offline
Default Re: Different VSO for different FPS?
What’s the Codec and is it different than the other frame rates?
Old 08-29-2023, 08:08 AM
smurfyou smurfyou is online now
I haven't noticed that but different codecs definitely do have different offsets.
Mine stays consistent with 23.98, 24, and 59.94 - DNxHR LB.
The display could also have something to do with it? If it has some sort of processing delay? Not sure about that but I suppose its possible.
~Will
