Old 01-20-2011, 01:12 PM
glenwoodedit glenwoodedit is offline
Default Ati Radeon 5770/5870 and Three Monitors
Hi All,
I thought I would throw this out there since I hadn't seen a current thread on this topic. We have found that in order to be able to get 3 working monitors out on the new Ati Radeon 577/5870 on the new 2010 Mac Pro's, you need to use the Dual Link adapters on the Display ports. Using the single link versions will only allow you to use 2 monitors at a time.
http://support.apple.com/kb/TS3477
http://support.apple.com/kb/HT4279
Also, if you want a somewhat cheaper alternative to the Apple adapaters, http://www.monoprice.com/products/pr...seq=1&format=2.
This gives you the ability to run an Edit, Mix, and Picture monitor under Pro Tools 9.
Old 04-22-2011, 03:14 PM
macaholic macaholic is offline
Default Re: Ati Radeon 5770/5870 and Three Monitors
I figured I'd revive this thread, to help others in the same boat.
If you are not looking to go super high resolutions (I'm using a couple older 19" LCDs as dedicated Soundminer and Meters screens, to flank my Cinema Display), I found these that work GREAT at $30 each. Specs say up to 1920x1200, but I'm just using 1280x1024 for my second and third monitors.
http://www.amazon.com/gp/product/B004071ZXA
A bonus is that it doesn't eat up a USB port for additional power, just remember it's only Single Link.
JC Richardson C.A.S.
Magick Lantern
Atlanta
Old 04-25-2011, 01:13 PM
Danny Caccavo Danny Caccavo is offline
Yes, we've used the Accell ones, and they work just fine for single link.
Old 04-27-2011, 07:45 AM
kd_special kd_special is offline
That sounds awsome
So just to be clear I have the 2010 Model Computer Graphics card HD 5770. If I buy 2 of those adapters listed above and use the DVI out of the HD 5770 I can display 3 monitors?
Right now I have a Mini DP to DVI adapter and the DVI connection hooked up. For 2 monitors and I did buy another Mini DP to DVI adapter and of course it didn't give me 3 monitors.
So Buy two of the adapters above Ditch my Mini DP to DVI adapters (because they are non active?) and Im good?
Thanks in advance
kd
Old 04-27-2011, 02:48 PM
Correct kd,
At least in my setup, which only required single link adapters.
Magick Lantern
Atlanta
HTML code is On
How to run an HDX2 with a 5770 graphics card? diamondschwin Pro Tools HDX & HD Native Systems (Mac) 7 01-16-2013 07:09 AM
ATI 5870 - Any issue with PT9? [R-DEV]Jaymz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-09-2011 09:41 PM
Is anyone using the ATI HD 5870 in Westmere 12 Core? toneski Pro Tools TDM Systems (Mac) 8 11-29-2010 06:22 AM
PT 8 and Radeon 5770 ivet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-01-2010 01:25 PM
Radeon 7000 Dual Monitors dans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-18-2002 09:41 AM
