Logic TDM work around
Just a quick tip.
Everything is set up round Protools in my studio, but the other day I had a client that wanted to work in Logic. I have been working with Logic TDM some years ago, so I though it was a no brainer setting up with my Digi ins and outs.... Hm. Not anymore cause as you know Logic doesn't support TDM anymore - you can only get 8 ch. with the Digi Core driver. So I did it like this: I have an 192D interface and then I bought a RME Raydat PCI card and connected the two via adat lightpipe. It gives me 32 ch i/o. Now I just have protools running in the background as a routing matrix whenever I'm running Logic and need the ins and outs. Also, I have an Aviom personal monitoring system that is also connected to Digi, and I have access to that as well. Boe |
Re: Logic TDM work around
same setup here, instead of the rme I use a m-audio profire lightbridge firewire interface, which gives me up to 32 adat I/O´s
MP5,1 12core 3.46ghz 96GB Ultimate HDX https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ |
Great - and I can even use my TDM plugs in PT on the way in on recording...
So are you connecting the lightpipe to the 192D purely to synch the clocks, or does audio pass through PT on its way to Logic? How do you get more than 32 I/O in PT using just one 192D, I thought that only did 16?
PT2023.12 - Mac Studio M1 Max 64GB RAM - macOS 13.6.3 - UAD-2 Satellite Octo/Apollo 8tb Duo/Apollo 16ii/Prism Lyra 2 - Euphonix Artist Control - All the plugins(!) Waves/PA/Slate/SSL/McDSP/UAD/Kush/SoundToys/Eventide/Softube/NI/PSP/Sonible/BABY/Fabfilter/Sonnox etc. |
I have two additional 96 I/O´s, so I can get more than 16 channels of adats
He is also right about the sync and the audio flow. Also - there might be some other cheaper options instead of 192D/96's with PT9 now beeing native... |
Logic pro and logic pro x doesn't work after mavericks | Sanderb | Artist Series | 3 | 12-20-2013 12:13 PM |
Logic with M-Box? Does it work? | Mikhail | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-26-2004 11:26 AM |
001 + logic 6 + osx or os9? does it work? | kalil | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-16-2003 08:25 AM |
001 / Logic / UAD-1 Does this work well? | Steve Rieck | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-06-2002 09:31 PM |
Does Logic work at all with 001??? | jorofino | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 03-16-2001 04:55 PM |
