Old 12-29-2006, 06:46 PM
devapro devapro is offline
Default I/O setup doesn\'t reflect my hardware setup
There is some history that I don't need to go into now but at at the present I have a 192 i/O and a 888/24 connected to the legacy port of a 192 I/O. Hardware setup shows both devices but when I go to my I/O setup the 888/24 is not there. It shows A1-16 and no B1-8. I have a back-up drive in the same Mac Pro with Pro Tools HD installed and everything is working fine. I've trashed every pref that Digi suggests but can't get the 888/24 to show up in the I/O setup.
Any thoughts would be appreciated.
Thanks,
Bruce
Old 12-29-2006, 06:54 PM
RobMacki RobMacki is offline
Default Re: I/O setup doesn\'t reflect my hardware setup
If I understand correctly, it sounds like you just need to rename your I/O paths from A1-16 to 192 and B1-8 to the 888/24.
Or you could import the I/O setting file from the back up drive and re set the I/O that way.
Old 12-29-2006, 06:56 PM
Craig F Craig F is offline
have you tried switching the 888 of in the hardwear setup then back on
than restarting the computer?
Thank you,
Craig
Old 12-29-2006, 07:05 PM
sorry I miss read "and no B1-8"
Old 12-29-2006, 07:09 PM
Are your port settings set to Legacy in HW Set Up?
Old 12-29-2006, 10:01 PM
Hi Rob, the port is set to legacy and I've chosen the 888/24 from the list. In the I/O window you only see the 192. The picture of the 888/24 is not there. I can boot off my other drive and everything is working correctly. It's very strange.
Bruce
Old 12-30-2006, 12:21 AM
Andre Knecht Andre Knecht is offline
[…] I've trashed every pref that Digi suggests but can't get the 888/24 to show up in the I/O setup.
After trashing the above, did you also empty the trash and then restart?
Consider zapping the PRAM.
Also, you may want to run the “CRON Scripts” (use Cocktail for that), and rebuild your System Drive’s directories with Disk Warrior.
IHTH. Good luck.
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 12-30-2006, 11:16 AM
Thanks for the reply. I know about the PRAM and I've got Disk Warrior but I'm not familiar with “CRON Scripts”and Cocktail.
Thanks,
Bruce
MIDI SETUP takes long to SETUP and doesnt SETUP DartagnanSosa87 MIDI 3 01-28-2013 12:02 PM
Can't "Launch Setup App" on Hardware Setup rjkool Pro Tools 9 7 01-31-2012 08:41 PM
Anyway of keeping the Hardware Setup...Setup!!! Imagine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-14-2003 03:26 PM
uh, help please...hardware setup... TheJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-01-2002 06:28 AM
HD Hardware Setup burningbusch Pro Tools TDM Systems (Mac) 6 04-04-2002 09:58 AM
