I/O Setup doesn\'t see 192 Dig I/O, Hdwr Setup does
I have an HD 2 system on a Mac G4 867 running OS 9.2, Pro Tools 5.3. I have one 192 I/O and one 192 Digital I/O.
A session suddenly started to freeze on me and play short loops, and the only way I could stop it was to kill the computer. So I reloaded PT 5.3. I can now play a session, but I am getting only a few outputs. When I look at the Hardware Setup, it looks fine. I see both the 192 I/O and (below it) the 192 Digital I/O. It properly shows I am using an external word clock at 96k and the 192 I/O is looped to the 192 Digital I/O. When I look at the I/O Setup, all the setup names are correct and the array looks right..........but instead of showing the 192 Digital I/O at the top (to the right of the 192 I/O), it shows a question mark. So, Pro Tools sees the 192 I/O, but doesn't see the 192 Digital I/O. I don't understand this, since it sees the 192 Digital I/O in the Hardware setup. I have reloaded PT 5.3 three times, same result. Any suggestions? Thanks, Mike |
Re: I/O Setup doesn\'t see 192 Dig I/O, Hdwr Setup
One thing I forgot to mention. I reloaded PT 5.3 using the original CD I got with the HD system. While finding the CD, I also found one that looks the same except it says on the left side of the label:
"For 192 Digital I/O". I don't recall ever using this CD. I don't even remember when I got it; maybe when I bought the 192 Digital I/O (which came later). I assumed it is for using when you have ONLY a 192 Digital I/O, and no 192 I/O. I shouldn't be using this CD for loading PT 5.3, should I? Too many CD's on the shelf! Thanks, Mike |
I just trashed DigiSetup in Preferences, then shut down the computer and all hardware. Then I restarted the hardware, then started the computer. This didn't solve the problem.
Re: I/O Setup doesn\'t see 192 Dig I/O, Hdwr Setup does
you are plugged into the Primary port not the Expansion port on the 192?
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Cables are:
-Main cable from Core card into 192 I/O Primary Port -Cable from Expansion port of 192 I/O to Primary Port of 192 Digital I/O. I don't think my problem is a cabling problem, since I have not changed any cables since the system was operating fine. I think it has to be a software problem. Thanks. |
did you trash your DAE prefs? and, for that matter, the DAE and reinstall that?
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
No. Is that a biggie?
I followed the procedure that Digidesign Tech Support gave me: -Move the DAE folder to the desktop. -Create a new Plug-Ins folder on the desktop. -Move all plug-ins from DAE folder to new Plug-Ins folder. -Search for "Pro Tools". -Trash all folders you find (I actually trash everything I find). -Search for "Digidesign". -Trash all folders you find (I actually trash everything I find). -Empty trash. -Load PT 5.3 from CD. -Download 5.3.1 Upgrade from Digidesign site. -Load 5.3.1 (I keep getting an error, haven't been able to successfully load 5.3.1). -Compare DAE folder on desktop to DAE folder on System drive. Move anything over that you want to keep. -Compare Plug-Ins folder on desktop to Plug-Ins folder on System drive. Move over anything you want to keep. -Trash the two folders on the desktop. -Empty trash. -Restart computer. So, trashing DAE Preferences would not occur (since I didn't do a search of "DAE"). Could this be the problem? I sure hope so!!! Thanks. |
Could somebody please comment on this procedure, before I go through it again?
Digidesign Support person around? I will add "Trash DAE Preferences" to the list. |
EDIT My bad, I didn't remember that 5.3.1 was HD approved. |
I'll post the procedure in another thread, since this "Subject" is different.
MIDI SETUP takes long to SETUP and doesnt SETUP | DartagnanSosa87 | MIDI | 3 | 01-28-2013 12:02 PM |
I/0 setup weirdness, sessions overwrite my setup | digidesigner | Pro Tools TDM Systems (Win) | 0 | 10-20-2011 11:40 AM |
PT 9 setup problem..Where are the MIDI IN options in setup menu?? | Blickerding | Windows | 0 | 04-06-2011 02:44 PM |
"Edit MIDI Setup" Setup Menu Item is Missing! | altemir | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-08-2004 12:24 PM |
OMS Setup: Interface Req'd? Setup referrences? | eltornado | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-19-2000 04:17 PM |
