Ati Radeon 5770/5870 and Three Monitors
Hi All,
I thought I would throw this out there since I hadn't seen a current thread on this topic. We have found that in order to be able to get 3 working monitors out on the new Ati Radeon 577/5870 on the new 2010 Mac Pro's, you need to use the Dual Link adapters on the Display ports. Using the single link versions will only allow you to use 2 monitors at a time. http://support.apple.com/kb/TS3477 http://support.apple.com/kb/HT4279 Also, if you want a somewhat cheaper alternative to the Apple adapaters, http://www.monoprice.com/products/pr...seq=1&format=2. This gives you the ability to run an Edit, Mix, and Picture monitor under Pro Tools 9. :) |
Re: Ati Radeon 5770/5870 and Three Monitors
I figured I'd revive this thread, to help others in the same boat.
If you are not looking to go super high resolutions (I'm using a couple older 19" LCDs as dedicated Soundminer and Meters screens, to flank my Cinema Display), I found these that work GREAT at $30 each. Specs say up to 1920x1200, but I'm just using 1280x1024 for my second and third monitors. http://www.amazon.com/gp/product/B004071ZXA A bonus is that it doesn't eat up a USB port for additional power, just remember it's only Single Link.
JC Richardson C.A.S. Magick Lantern Atlanta |
Yes, we've used the Accell ones, and they work just fine for single link.
So just to be clear I have the 2010 Model Computer Graphics card HD 5770. If I buy 2 of those adapters listed above and use the DVI out of the HD 5770 I can display 3 monitors? Right now I have a Mini DP to DVI adapter and the DVI connection hooked up. For 2 monitors and I did buy another Mini DP to DVI adapter and of course it didn't give me 3 monitors. So Buy two of the adapters above Ditch my Mini DP to DVI adapters (because they are non active?) and Im good? Thanks in advance kd |
Correct kd,
At least in my setup, which only required single link adapters.
How to run an HDX2 with a 5770 graphics card? | diamondschwin | Pro Tools HDX & HD Native Systems (Mac) | 7 | 01-16-2013 07:09 AM |
ATI 5870 - Any issue with PT9? | [R-DEV]Jaymz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-09-2011 09:41 PM |
Is anyone using the ATI HD 5870 in Westmere 12 Core? | toneski | Pro Tools TDM Systems (Mac) | 8 | 11-29-2010 06:22 AM |
PT 8 and Radeon 5770 | ivet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-01-2010 01:25 PM |
Radeon 7000 Dual Monitors | dans | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-18-2002 09:41 AM |
