Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 04-13-2023, 09:18 PM
digizaemon digizaemon is offline
Default about MTRX Thunderbolt 3 Module
I have a question about the MTRX Thunderbolt 3 Module. Is it Thunderbolt Core and this product are the same?
Old 04-13-2023, 11:16 PM
BScout BScout is offline
Default Re: about MTRX Thunderbolt 3 Module
The module works in two systems (MTRX Studio and MTRX II). They don't operate the same in both systems. MTRX Studio = 64 channels. MTRX II = 256 channels. Hardware restriction.
Thunderbolt Core and MTRX II operation are the same (256 channel)
Old 04-14-2023, 01:26 AM
Is latency the same as this?
Near-Zero Latency
The Thunder|Core interface uses a Thunderbolt 3/PCIe connection and data transfer with 2 samples latency on the connection and a total of 9 samples in the digital interface. With up to 256 audio channels at 48 and 96 kHz, and the latency at 96kHz is 95 microseconds.
Old 04-14-2023, 03:13 AM
RobertDorn RobertDorn is offline
Near-Zero Latency
Yes, Mark Corbin of AVID says it’s exactly the same performance. However, 100% understand your question because I have trust issues with a company taking apart a product sold as a whole by the OEM manufacturer, to sell it in pieces
James (uptheoctave) has an AX64 and will take a look inside his unit if the the Thunderbolt card on the AX64 in fact also is a slotted / removable module
Apple MacBook Pro M2 Max, 96GB ram | Pro Tools HDX | Avid MTRX | Pro Tools Ultimate 2023.12 | macOS 13.6.3
Old 04-14-2023, 09:38 AM
ntp-jl's Avatar
ntp-jl ntp-jl is offline
The main interface to a computer on an MTRX 2 is DigiLink and not Thunderbolt. This is why MTRX comes with DigiLink as standard and Thunderbolt as an option.
The main (and only) interface to a computer on an AX64 is Thunderbolt. Without the Thunderbolt interface you could not connect an AX64 to a computer. This is why Thunderbolt is included as standard in the AX64.
It's as simple as that! There is no secret conspiracy involved in this.
The performance of the Thunderbolt interface in an MTRX 2 and in an AX64 is EXACTLY the same because it is the same module. And yes, the Thunderbolt interface in the AX64 is a removable module, but if you removed it, you couldn't connect the AX64 to a computer. So why is it relevant whether you can remove the module or not?
Jan Lykke
Business Development Manager
DAD - Digital Audio Denmark
Old 04-14-2023, 09:54 AM
Hi Jan, thanks for confirming the Thunderbolt 3 interface module is exactly the same board on the AX64 as on the new MTRX II .
The rest of your explanation, of course, is pure marketing talk, following your philosophy you'd actually say your very own AX32 can't interface with any computer because it hasn't Thunderbolt nor it has DigiLink.
Digilink is not an interface, it's just a connector to connect to an interface, like MADI, AES, Adat and Dante could be connected to an interface.
It's a shame AVID decided to make the Thunderbolt3 interface module on the MTRX II, which on its own costs over $2000 more than an AX64, an optional purchase.
Old 04-14-2023, 10:44 AM
Oh and to answer this specifically, it's relevant because it confuses end users when there's a new range of Thundercore DAD products released since 2022, with Thunderbolt connectivity as a standard on the chassis, transforming the great DAD converters into actual interfaces.
And then approx a year after AVID releases its digilink take on the AX64, brining it back to just a converter again like 10 years ago (quite revolutionary ehh...) with an optional to be purchased Thunderbolt card.
For me it's quite obvious this raises initial questions at the end users side, if the performance will be equal with a user installed thunderbolt card compared to the integrated Thundercore system as released initially by DAD.
Again, thanks for confirming that eventually the modules are exactly the same.
Old 04-14-2023, 01:45 PM
I can see how they arrived at that price: AX64 - thunderbolt module + digilink card (and I guess we're ignoring the ADAT ports).
So AX64 ($5k) - thunderbolt module (-$800) + digilink card ($2200) = $6400. And the MTRX 2 is $7k.
Old 04-14-2023, 06:29 PM
Yeah right. An AX32 is $3999 and a (discontinued) MTRX is listed at $5599 , so then at once 2 digilink connectors are just $1600.
The MTRX II is an overpriced, half functional box compared to its AX64 competitor. Highly unattractive for current MTRX owners.
Old 04-14-2023, 08:39 PM
The 2 digilink connectors are $2200 currently (single card.) The AX32 came without dual power supplies or Pro Mon licensing. Those were additional costs beyond the base unit. Avid had the MTRX have those standard.
We still have a loaded AX32 (pre Avid/DAD partnership) with digilink. I remember all these costs. (I realize you are in the Netherlands so to clarify, I'm giving all these costs in US$)
The MTRX II should have been priced at $6500 is my opinion.
s6 Automation Module and Joystick Module Layout Setup Funkster Avid S4/S6 3 01-30-2023 08:09 AM
Apple Mac M1 MTRX Studio HD Native Thunderbolt IrelandM Pro Tools HDX & HD Native Systems (Mac) 19 01-07-2023 03:01 PM
MTRX Studio Headphone Outputs vs HD Native Thunderbolt Box scottmckay Pro Tools | MTRX & MTRX Studio 3 07-28-2022 09:22 PM
MTRX Sources - >Trinnov MC16 Dante ->MTRX Out routing ??s Jeff Schmidt Pro Tools | MTRX & MTRX Studio 4 03-18-2022 02:21 PM
MTRX optical MADI SFP module Pythagor Pro Tools | MTRX & MTRX Studio 3 06-04-2021 07:16 AM
