Fatal error
I'm gonna go with... what?! It worked just fine to activate the plugin, so I suppose I can just fogeddaboudit?
Thanks. http://imageshack.us/photo/my-images...esourcesg.png/ http://imageshack.us/photo/my-images...rrorqddmn.png/
Re: Fatal error
Pro Tools is throwing multiple fatal errors during launch all of a sudden, and then just disappears. I have no idea here, and I have trashed "all" the usual suspects...
Re: Fatal error
Ran Digitest a couple times, and all 3 cards passed.
Re: Fatal error
Installed a fairly current backup system drive, and ran Disk Utility on the other one. Sorry for the unsharp images. I don't know how to make them any sharper with this file size.
Re: Fatal error
Clean uninstall and re-install to replace ALL PT program files. Trash prefs in between and repair permissions and all that stuff. If its not fixed by the install then look at your system drive and audio drive next. Chris
Re: Fatal error
Thanks, Chris.
I'm gonna throw away the system drive. Got all kinds of errors, and in the end it wouldn't even boot. I had everything up and running on the backup drive, and it ran fine for a while, but now I'm getting fatal errors on that drive too. I have done a clean uninstall of PT, and tried to repair permissions before a reboot, but Disk Utility threw a "First Aid failed" error message. I find it hard to believe that both drives collapses in one day. Can it be RAM? Can the second installed drive (audio drive) in the PPC be in such a state that it somehow interfers with the system drive?
Re: Fatal error
New update...
The G5 won't reboot. It's stuck with a grey screen, and the fan(s) are blowing full speed.
Re: Fatal error
If you look inside the G5 chassis from the front, do you see any red LEDs illuminated?
Re: Fatal error
I can only speak from PC experience but this is not good news. You might try turning it off and and removing the memory. Try booting it without any memory then try it one stick at a time. Email me if you need help. Chief Technician or Toolbox would be more help.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Re: Fatal error
Zapping pram was one such treatment for a bricked G5. Also try pulling the power plug and holding the power on button for 20 seconds.
Buttdialed by me & Tapatalk
Fatal error, 7.4 | luris | Pro Tools TDM Systems (Mac) | 13 | 12-05-2007 02:05 AM |
Fatal Error | RichrdC | Pro Tools M-Powered (Win) | 2 | 06-17-2007 10:55 AM |
Fatal Error? | Frank Kruse | Post - Surround - Video | 0 | 01-12-2007 07:22 AM |
Driver error, DAE error, Fatal Exception | jammack | Pro Tools M-Powered (Win) | 0 | 11-25-2005 01:01 AM |
WTF!!! Fatal error and now PT is gone?!?!?! | riffing | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 06-02-2003 02:29 PM |
