8 track deliverables format?
What is the general standard for printing the dialog, music and effects on DA88/98?
1-track configuration 2-ref level(i'm assuming -20) 3-slating 4-anything else thanks |
Re: 8 track deliverables format?
However, if dealing with a program that is tied, then neither are required. (Do not put an Academy on a tied master-it will only serve to confuse the recipient) Quote:
Hope this helps- Todd A. |
A couple of novice questions for The Chinese. What do you mean by a tied master? What exactly is Academy leader? Do these terms apply to ad work or just feature work? Sorry for the amatuer stuff.
An Academy Leader is the Film "leader" that you see sometimes on old movies with the seconds counting off, the sweeping hand, then a Sync Pop on the "3", which is the 3 FOOT mark. (Film is measured in Feet+Frames, with 24frames going by each second.) The Academy Leader is 12 Feet. It is not used in AD work, as it is TV. Hope this answers your questions... -Todd A. |
I must repeat, it all depends on what you're doing and what the client or broadcaster asks for.
For example. Alot of shows we do for Discovery etc. Layout is as follows: Channels 1+2: Full Stereo Mix Channels 3+4: Stereo Music Channels 5+6: Stereo FX Channel 7 : Voice-Over Channel 8 : Interviews On a Cartoon we had to also deliver: Channels 1+2: Stereo Music Channels 3+4 : Stereo SFX Channels 5+6 : Stereo BG's Channels 7+8: Stereo Dialogue. |
Unfortuunately, this varies from broadcaster to broadcaster. So you need to check with the client.
Mark |
Always ask for a copy of the client deliverables, this will list the DA88 track config and also any other format required.
We do stuff for Discovery and what we're asked for is different to what others are asked for (maybe because we're in the UK, I don't know?) We are asked to provide a splits DA88: 1&2: Dialogue/Sync 3&4: Music 5&6: FX & Atmos 7: Narration 8: Quotes/Translations As well as providing the Final Mix & M&E on the DigiBetas. So basically there is no standard.....! [img]images/icons/rolleyes.gif[/img] The Sound House Post Production Ltd.
Sarah x |
Hello. As was ponted out by several people, directly or indirectly, there is no set standard. It depends on the client and the project. Sometimes they'll want an international version, an airplane version, etc. and each will have different requirements. Different clients will have different requirements for different things. As was also pointed out by most everybody, ask the client, ask twice, ask three times and be very, very clear and thorough with labeling.
froyo |
Anders,
Here is the proceedure that I use. Before you start mixing, ask the client for a copy of the Network or Delivery specs. Do this at the start. This will determine what levels you deliver track layout and the way you mix the show. Any tape that leaves your studio should be marked with name of the show, the date, the track layout, your sync rate, drop or non drop your name, the studios name, address and contact number. This way most questions that anyone will ask will be answered on that tape. If not then they can contact you. I agree with "The Chinese" (Todd) that most tapes if they don't request a particular layout should be Dia, Music and then Fx. I also deliver another D-88 of a 5.1 mix on tracks 1- 6 of the D-88 and an Lt./Rt on 7-8.There should be no slates past 15 sec before program starts.There should be tone of at least 30 sec a minute before program starts. Once again it's delivery specs. As for the Academy leader you can have a 2 pop if it's on your tape (Video Master) or sometimes for Foreign since some shows go back to Film instead of delivering a NTSC Video clone.On a side note everything I mix is always in Surround and has been fot the last 12 years. If you have the ability to provide it, DO IT! It seperates you from your competition and if you can go one step further deliver them a 5.1 mix also. That is where your monitor matrix comes into play. By now you all know what I have so I won't get into that. Finally it is nice to see everyone sharing their insite and experience here. It's good to see people I know in Hollywood like "The Chinese" (Todd) who I met through the DUC. He is a very knowlegeable guy who I'd love to mix with someday. Keep the info flowing!
Marti D. Humphrey CAS aka dr.sound www.thedubstage.com IMDB http://www.imdb.com/name/nm0401937/ Like everything in life, there are no guarantees just opportunities. |
Academy deliverables??? | stormmusic | Post - Surround - Video | 5 | 05-25-2010 08:43 PM |
FPS Deliverables | mellow1998 | Post - Surround - Video | 19 | 07-08-2008 12:32 PM |
Can't Bounce the track to disk using an MP3 format | Rybo15 | Pro Tools M-Powered (Win) | 2 | 03-27-2008 07:07 PM |
5.1 track format view | Andy_P | Post - Surround - Video | 3 | 02-20-2008 04:09 PM |
How to "Bounce/Save" track as a DATA file/format | LaForestPoetry18 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 07-24-2006 10:49 PM |
