pc to mac file conversion???
help. I switched from pc to mac recently. the mac recognizes the discs from my pc but when I launch pro tools it doesn't play the files. you can see the track names in the edit window but there's no audio. any clues? are there any tips for converting files pc to mac?
thanks |
Re: pc to mac file conversion???
What kind of disk?
What kind of files? Have you used any other software to try and open the files on the Mac like SoundAPP or SoundRecorder?
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Did you enforce mac/pc compatibility in the session?
thanks, how do you enforce pc/mac compatibility?
greg |
From the What's New in Pro Tools 5.1 document:
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Cross-Platform Support Pro Tools 5.1 features a cross-platform session file format that lets you open sessions on both Macintosh and Windows platforms without first converting them. AIFF and WAV format audio files can be recorded and played on either platform.<HR></BLOCKQUOTE> You need to have Pro Tools 5.1 or higher on both systems: <BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>In order to share Pro Tools 5.1 sessions between Macintosh and Windows, the “Enforce Mac/PC Compatibility” option must be selected when creating the session, or when saving a session copy.<HR></BLOCKQUOTE> Do a Find in your PT Reference Guide v5.1 for the word "enforce" and you should find more details. If you have the ability to go back to the PC and open the sessions on v5.1 or 5.1.1, you can "Save session copy..." and choose the enforce Mac/PC option at that time. Otherwise, you're probably going to be limited to importing tracks and lining them up at the beginning of the session. If you don't have Pro Tools 5.1 and need to convert .wav files to .aif, you can use something like SoundApp or QuickTime Pro on the mac. Or you can upgrade to v5.1.1 which will import .wav files, as will PT 5.1. I don't remember if v5.0 or 5.0.1 can use the "import and convert" feature in Pro Tools to bring .wav files in, but you can check to see if that is possible in your version.
Administrator Avid Pro Audio Community |
When you say there's no audio do you mean no SOUND or no visible waveform? In other words, is there any evidence of successful data transfer beyond the track name?
jla |
ptf File conversion | jamesimm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-03-2012 11:59 AM |
DVD Conversion (Vob File) for PT | deek | Pro Tools M-Powered (Mac) | 4 | 12-02-2009 11:38 AM |
File Conversion | 1511 | Pro Tools TDM Systems (Mac) | 8 | 12-02-2006 12:05 PM |
SD2 file conversion | Ian Wallace | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-29-2006 03:28 PM |
Need File Conversion Help? | SteveGarman | General Discussion | 2 | 03-27-2001 09:53 AM |
