Old 05-14-2023, 02:06 PM
TheMightyQuinn TheMightyQuinn is offline
Default Sonarworks Reference 4 Measure
Anyone running an OMNI / HDX setup using Sonarworks 4 who knows how to setup Reference 4 Measure?
For the life of me I cannot setup Measure to output through the OMNI. I can get input to / using channel one, but none of the options being listed in the output menu in the Measure pull down outputs sound. I would guess that the OMNI should be listed here, but nothing I have tried will provide that choice.
I contacted Sonarworks Support and got back a rather vague reply saying, "Avid hardware can be a bit tricky that way, I can recommend checking that your interface is currently not reserved for/being hijacked by Pro Tools when trying to use the Measure app." I not sure what, "reserved" means or how to un-reserve.
I've tried running Measure without opening ProTools, as we'll as after opening Protools.
I understand that Reference 4 is not the latest version, but I have made this work once in the past a few years ago, but recently moved and wanted to run new calibrations. My setup is largely unchanged from my last run, so I obviously figured it out back then or it just worked. I honestly can't remember.
In advance, any assistance will be appreciated.
Apple Mac Studio M2 MAX, 10 core, 96Gb RAM, 1Tb HD, macOS Ventura 13.4, Pro Tools 2024.3, AVID Omni HD, 2x AVID I/O, 1x HDX, Sonnet Tech Echo Express III-D (Thunderbolt 3 Edition), UAD-2 OCTO PCIe.
Old 05-14-2023, 04:20 PM
massivekerry's Avatar
massivekerry massivekerry is offline
Default Re: Sonarworks Reference 4 Measure
I think you need to not have Pro Tools open, and you need to (shoot, it's been awhile at this point) set the card/Omni so that CoreAudio is using it as an I/O in the Mac Sound Preferences. I forget what the exact terminology is, but It won't do that with Pro Tools running.
Kerry Smith
http://apothekerry.com
Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro
Old 05-16-2023, 06:31 PM
Thanks, Kerry!
Still no go here. Tried looking into your recommendation here as well as trying everything else I can think of. Nothing.
Frustrating that no one seems to know what it takes to use this software - especially saddening that Sonarworks can't give more than just a passing 'shoulder shrug' supporting their own software. It's not like Pro Tools is some unknown DAW used by nearly no one. Even more saddening that I can't remember at all what I had done to get Measure working when last used. Sigh...
Old 05-16-2023, 07:42 PM
Originally Posted by TheMightyQuinn View Post
Thanks, Kerry!
Yeah, the level of cluelessness in support that appeared at Sonarworks when they rebranded as SoundID has not been comforting.
I had an HD native and HD IO, previously (Team Carbon since January) and I recall setting up a CoreAudio device (but I don’t recall the nomenclature) for it and running the Reference Measure app standalone to capurture the EQ profile without issue, but it’s been a few years. (Carbon works differently). I do think you have to have CoreAudio things for the Inputs and Outputs, and the system has to be assigned to use both…?
Kerry Smith
Old 05-17-2023, 12:24 PM
Hmmm, A couple of things to remember:
1-try doing the measurement at 44.1K(I remember that was a "must" back when I bought my version 4 package)
2-do NOT have Pro Tools open
3-unless you are measuring more than stereo, you can do the measurement with any interface. My 003 would not work, but I borrowed a friend's little Behringer USB interface and the entire process went thru without a hitch.
Old 05-18-2023, 03:24 AM
Will Russell's Avatar
Will Russell Will Russell is offline
You may have done this already, but I would first make sure the ProTools is actually quit. Then I would go into your Mac system preferences under the sound pane and select your omni as your Mac input and output. I do also remember that the sample rate I think was limited to 44.1.
Hope this helps!
Will Russell
Electric Wilburland Studio
https://linktr.ee/wilburland
M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock
M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS
Old 05-18-2023, 08:29 AM
Hope this helps!
Hi Will,
My ONMI is not an output option in my Mac's System Preference Sound settings.
Thx!
Old 05-18-2023, 08:31 AM
Hello,
After employing a 3rd party interface and abandoning my AVID hardware for this purpose, I've been able to successfully run calibrations.
Thanks for all of the replies here! Much appreciated.
~ Greg
Old 05-18-2023, 09:35 AM
Hi Will,
Thx!
The Omni itself won't show up as an option in Mac system sound, but rather the device to which it is connected: HDX or HD Native.
Scott Gatteño
Old 05-21-2023, 01:37 PM
Matt Hepworth's Avatar
Matt Hepworth Matt Hepworth is offline
This. And only in CoreAudio mode.
Sonarworks Reference problem Danny_79 AAX Plug-ins 18 05-28-2023 07:50 PM
Sonarworks Reference plugin gwbigfish AAX Plug-ins 5 01-19-2022 06:31 AM
FS: Sonarworks Reference 4 $145 crandallwarren Buy & Sell 1 05-24-2020 06:46 AM
AAE -30001 error w/ Sonarworks reference 4 stephen.r.banville Pro Tools 2019 11 10-17-2019 07:32 AM
Sonarworks Reference 4 ASIO Wawili_Sound Pro Tools 2018 2 01-22-2019 11:58 PM
