Old 10-03-2013, 06:02 PM
firsty33 firsty33 is offline
Default How Do I Make A Pump/Chorus Beat?
Hello,
I'm inquiring on a trick that I would like to learn. I have a link posted below to a song that has this ever so cool "pump chorus". I've been trying to figure out how to do it, and it seems all the hit dance/pop songs are using it. I hope you guys know what I'm talking about? If you listen to the song posted in the link, skip forward to the chorus and you'll hear it. My guess is they're using a heavy compression to side chain with the kick drum... I could be totally wrong, and that's why I'm asking for some help! Thank you guys!
-Justin
http://www.youtube.com/watch?v=dGghkjpNCQ8
Mac Mini OS X 10.8.5
2.3 GHz Intel Core i7
16 GB 1600 MHz DDR3
Pro Tools 10, 003 Rack, NI Maschine
www.youtube.com/firsty33
Old 10-03-2013, 06:52 PM
Southsidemusic's Avatar
Default Re: How Do I Make A Pump/Chorus Beat?
Honestly i am not sure what you mean with "pumping chorus" but if you mean the heavy limiting and side chained bass and kick then yes, that is what they did on this track. My collegue was there with Calvin when they put vocals on that song and we use that "effect" on all our edm/pop-house songs.
You just sidechain the bass with a kick and set compression VERY HARD and if you wanna make the pumping more predominant on the track just add a "key chord" to the sidechain track and set the compression accordingly
Best of luck
Chris
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 10-04-2013, 09:07 PM
SouthsideMusic, thank you that was simple and extremely helpful! I sent you a private message, did you receive it?
16 GB 1600 MHz DDR3
Old 10-06-2013, 11:54 PM
Raoul23 Raoul23 is offline
Best of luck
Chris
Thanks soundside when you say Key Chord what do you mean by that. Would like to learn this trick :)
Sent from my iPhone using Tapatalk - now Free
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 10-07-2013, 01:21 AM
Hi
When we do that kind of trick we lay down a 3-4 note chord and sidechain that track to the same compressor/side chain comp that the kickdrum generates and that way you will have :
1 kick drum on a track with a heavy compressor.
2 side chain the bass track (send the signal from the kick track to the compressor on the bass track and the track with the chords you want to have pumping and that way you get both bass and chords sidechained from the kickdrum and it sounds awesome. You need to have the same type settings ( comp value etc ) on both the bass and the chord track so they pump in sync. We use the same settings on kick, bass and chord track compressors so we have a tight sync'd pumping and preferably a 4/4 ( 4 on the floor) beat.
EDM producers and house/dance producers do this most of the time and it works great for that type of pump feel.
Post back if you have any additional thoughts and I will try and help out as much as I can on that subject
Best of luck
Christopher
PS. I got your PM and I will send you a PM as soon as I can.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 10-08-2013, 10:26 PM
Hi
Best of luck
Christopher
Thanks Chris I'm gonna be trying this out very soon :)
Raoul Crane
Old 10-09-2013, 08:04 AM
Hi
Best of luck
Christopher
Chris, can you explain how to lay down a 3-4 note chord? And I look forward to your PM!
16 GB 1600 MHz DDR3
Old 10-09-2013, 11:57 AM
Sorry if I was vague, I meant like a normal #C #E #G or something and make the chord progression follow the notes you played your bass so you don't have only the bass notes/arp sidechained but also a chord that plays along in the same key and follow the bass and sidechain track to the same track that you sidechain the bass from
If you want I can email or post a link to something this weekend that We made for a famius artist from the US. We used this "trick" on the two songs we sold to her and it is EDM/Pop-House/Dance.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 10-09-2013, 12:17 PM
Yes, a link would be great! I mostly understand what you're saying, but I will know more about what you're explaining when I try it out.
16 GB 1600 MHz DDR3
Old 10-29-2013, 04:40 PM
Hi
Best of luck
Christopher
Thank you for your sharing your knowledge, it helped! Did you get a chance to PM back?
16 GB 1600 MHz DDR3
how to make beat on PT fredson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-02-2008 10:57 AM
Beat detective to make drums tight Niels Vejlyt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-12-2007 09:17 PM
pump up the volume Jannie Pro Tools TDM Systems (Win) 3 03-15-2004 10:16 AM
pump up the volume Jannie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-12-2004 10:04 PM
Pump Audio brdst General Discussion 0 07-18-2003 08:55 AM
