Delay and loss of sound quality? Any help?
So I am having some problems with my ProTools LE 8 and was wondering if anyone knew anything I could do about it. I am experiencing a delay in my input instrument when I playback what I already recorded. My guitar is delayed compared to the already recorded track making it almost impossible to keep time. Whenever I turn the mix down the whole way everything is fine, but then I cannot hear the mix to record to it....any help? Also, I am losing sound quality when I playback a recording. It sounds fine while I am play it but as soon as I record it and play it back, it sounds bad. Help please?!
Re: Delay and loss of sound quality? Any help?
Lower your h/w buffer setting in setup/playback engine. Set it to 64 or 128. Loss of quality? Hmm, make sure you aren't recording too hot is all I can think of with the info you provided.
www.HellfireBeats.com UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61 Pro Tools 2021.12 Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2 16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1 27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15 |
thank you, I'll try that. Anyone have any ideas on why the quality is bad?
The odd thing is, generally, what you hear going in(on the headphones or speakers) is generally exactly what comes out. Maybe a detailed explanation of exactly what you are recording, and how(every piece of equipment and cables may affect the final product).
I cant think of anything it would be. Im using the mbox2mini with standard guitar cables running into the mbox. then the mbox is plugged into a guitar amp as the output speaker system with a standard guitar cable. it cant be the amp because I also had it plugged into computer speakers and I got the same sound. could it be the cables?
What "inputs" on the amp are you using?
theres only only input on the front of my amp. just using the normal input1, that is plugged into the Mon out of the mbox.
Try lowering down the mix and lowering up the input on the mbox
A guitar amp is NOT a good monitoring system. They are anything but flat or accurate. Try some real studio monitors(in stereo). If you're on a tight budget, look at the Behringer 2030A as they are only about $229 a pair and are tough to beat in that price range.
I don't think its the amp, because I have played it through my computer moniters and got the same sound. thank you for the help though.
kbronctjr, Ill try that and see what happens. |
Questionable quality loss | JimHalpert | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-17-2010 05:39 PM |
Is there ANY loss of quality when duplicating? | cheekypaul | Tips & Tricks | 2 | 02-22-2005 10:18 AM |
Upsampling 48k to 96k Quality Loss? | perspectrum | Pro Tools TDM Systems (Mac) | 1 | 02-23-2004 09:25 PM |
Loss of quality after bounce | CRM-114 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 01-23-2004 08:43 AM |
Why does consolidation &or bouncing tracks=loss of sound quality | John Kurzweg | Pro Tools TDM Systems (Mac) | 38 | 07-24-2003 07:22 AM |
