what preference am I looking for? plug window display behavior
I'm posting this in two forum locations, since I'm new to using a D-Command, and I'm not sure if this is happening because of the controller, or if it's a preference I haven't run into before.
The scenario is I want to create a send from, say, a snare track to an aux with a verb on it. I have the window for the verb plug open, and I want it to remain visible, but when I create the send from the snare track, the plug window switches to whatever the plug is in the same insert slot of the snare track. Is there some kind of preference I need to switch to change this behavior? I want the GUI of the plug in the aux to remain open when I go to another track to make a send that goes to that aux. Is this related to the focus track on the D-Command? What are some key words I should be looking up in the PT reference manual or the D-Command guide? thanks a lot--Kevin |
Re: what preference am I looking for? plug window display behavior
Yes, focus mode is where you need to look at.
Also, you can have the plug windows open all the time if you option click (or was it shift or apple?) on the target-looking red ring things in the upper right corner of plugin windows. |
Waves preference dialog window wont go away | S.TaylorRCC | Windows | 5 | 06-12-2021 06:27 AM |
Urgent Help Needed | Cant open PT 8.0.3 Preference Window | 25ghosts | Pro Tools TDM Systems (Mac) | 2 | 02-25-2010 07:30 PM |
what preference am I looking for? plug window display behavior | bashville | ICON & C|24 | 2 | 04-08-2009 09:31 PM |
suggestion for NEW PREFERENCE : TARGET BUTTON in Plug-In-window (standard: on/off) | Helge Schwarz | Pro Tools TDM Systems (Mac) | 0 | 08-12-2008 03:07 AM |
Strange Pop Up Window and Behavior with QT / 6.9.1 | AVGuru1 | Post - Surround - Video | 2 | 02-07-2006 05:53 PM |
