#21
Re: Drums Buried In The Mix
-3db is extremely high assuming you're talking about dBFS. That's virtually no headroom. The best practice in Pro Tools is to shoot for between -18 and -12 dBFS. This gives you more than enough dynamic range (bit depth) and leaves plenty of head room for unexpected peaks during the recording process. We also don't know where your faders are at when you are trying to mix, but if you have your recorded levels hitting -3 you're going to have to bring the drum faders WAAAYY down to leave room for everything else. Not only do you want your recording levels between -18 and -12, but you want your Master Fader showing something to that degree as well with peaks hitting about -6dBFS.
As far as unburying your drums, the previous comments are pretty much spot on - build your mix from the drums up. You haven't said anything about EQ either, and I suspect there's some frequency masking going on here. Without hearing your mix I'll just give some general things I consider with drums. : Are the kick drum and bass guitar playing nice? Check that you don't have any masking going on between them. Anything metal (cymbals) usually benefits from a (shelf) boost around 10k and a dip of the mid range somewhere between 800 and 2k (this will also probably help separate your cymbals from the guitars you recorded). Stick/beater hits (attack) usually lives around 4k. Muddiness is usually around 250. This is all, of course, dependent on the actual kit and the recording process. If we could hear your project we could probably help more :)
----I was thinking of taking a solo in the bridge. -Nah, I don't think that would sound good. ----Ok, well how about just a series of cool riffs? Mac Pro 2008 (Harpertown) -- OS X 10.8.2 -- 16GB RAM -- WD Black Drives -- UA Apollo Quad -- Pro Tools 10 w/ CPTK |
#22
Also just because something sounds great by itself doesn't mean it will sound great in a mix. It may but sometimes you have to tweak to a point were it sounds weird soloed but great within the context.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
#23
Yes.
#24
Might I also add: mix with your ears, not your eyes.
Ideally we should be able to close our eyes and adjust the mix without watching the knobs. Building up the mix, all the time thinking how could each track sound better, a bit brighter? a bit darker? a bit farther (reverb)? panned? The relationship between tracks and so on. And not be afraid of leaving a well recorded instrument alone and plugin-less. "I've added EQ and compression to all the tracks an it still sounds crap." Yes. Say no more. Firsty33, I checked out the video. This kind of heavy metal saturated music is very hard to mix. Not too bad job you had done. But in my opinion the snare was too loud and kind of detached from the mix. The guitars should be way louder, punchier and and driving the sound. I use a couple of simple techniques to check and fine-tune the mix and the balance between instruments: press play, go to the toilet, on the way back when you start hearing it in the distance you often realize that something is too loud, too soft. And check your mix on a boombox, car stereo, laptop speakers, in a noisy bar etc. A good mix works on anything.
#25
OK I watched that video--first off, sorry about your friend.
Since it's a tribute to the drummer, I'm sure the idea of a typical balance is maybe out the window.But if you wanted to bring that into some kind of reality, my main thought is that the kick feels light, and I think once the kick is raised, that will let you bring all the other instruments up (bass, guitars, voice) because they'll be supported by the thump. Or the reverse would be bringing down all the drum mics EXCEPT for the kick just a tad and see what happens. Everything actually sounds pretty well recorded. The short version is that it sounds like the drums are actually too loud on that, except for the kick. I agree with the previous poster that the guitars seem light--what I'm guessing is that this might be more of a monitoring problem. Do you have a problem with standing waves in your listening space? That can really skew your perception of what's going on in the the bottom. So the idea of changing your listening perspective is good. Also I'd like to emphasize listening and comparing to well-chosen reference tracks. And one thing I've found really useful recently, which kind of switches me out of musician mode a little bit, is to avoid listening to long stretches of the piece at a time. Your ear starts justifying what it's hearing, focusing more on musical events (ironic, I know). It's another temporary perspective shift to try. Listen to shorter sections that you're focusing on, like drop the needle. Fix the issues you hear, then be aware of where the texture changes and might require automation or splitting a track into multiple sections to deal with special issues. If you listen too long to something that's "wrong", your ear begins to adjust to make it seem "right". Then you compare it with a CD you like and suddenly you realize how far away you've drifted.
HD Studio, PT2022.6, UA Apollo x6, 2018 MacBook Pro, 32 Gig, Big Sur |
#26
If all his guitar/bass tracks are all at -3db peak level I think the master fader will get clipping. |
#27
You guys are absolutely amazing with this priceless advice. I want to first and foremost thank you all. I apologize for not replying to your answers earlier, since I didn't receive any more email notifications about this thread I assumed the discussion ended, boy was I wrong! I've been putting long hours in the studio, and our project is almost finished. I will give you the link when they're ready, shouldn't be long. Thanks again, you guys inspire me with your wisdom, truly.
-Justin
Mac Mini OS X 10.8.5 2.3 GHz Intel Core i7 16 GB 1600 MHz DDR3 Pro Tools 10, 003 Rack, NI Maschine www.youtube.com/firsty33 |
#28
Lol!! I thought I was the only one to do this. I've been doing it for years and no one ever taught me it.. It just happened one day while I was running a mix down and I was coming back from the bathroom. I thought to myself "wow that guitar is way too loud. Glad to hear others use the 'proximity to mix' test for balance issues.
Rig 1-Mix/Mast: PTHD 11.3.1; MacPro 6core (6,1) 3.5 GHz Xeon E5; 10.10.3 (SSD Drives for audio); Apogee DUET, FireStudio2626 as Hware Inserts to PT for outboard Rig 2-Cutting&Remotes: PTHD 11.3.1; MacBook Pro (8,1) 2.8 GHz Dual i7; 10.9.2 (128GB int '6G' SSD drive); Profire LightBridge (FW800), 32ch Presonus Digimax FS |
Adding MIDI drums to acoustic drums - Velocity | Pat.m | Pro Tools 11 | 5 | 11-01-2013 08:40 PM |
Snare getting buried in mix | Raoul23 | Tips & Tricks | 9 | 10-26-2010 05:14 AM |
Thank the Lord analog is almost buried! | electrok | Pro Tools TDM Systems (Mac) | 8 | 02-17-2005 09:15 PM |
Electric Drums vs, regular drums as input to PTLE | mfleming | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 01-27-2005 03:07 PM |
Multiloops - Discrete Drums - Reel Drums | davidp158 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-18-2002 12:35 AM |
