ATTN: Mix hardware users - Scrub bug
If any Mix hardware/OS X users out there are experiencing a bug where when you scrub audio Pro Tools loses communication with the hardware and reports a DAE error 6039, PLEASE post your system information here in this thread and provide the following info:
1) What Mac are you using ? 2) Do you have an expansion chassis? 3) How many mix farms/DSP farms are you using? List all of them! 4) What version of Pro Tools are you using? 5) What version of MacOS X are you using? 6) What DAE buffer are you using (ie - 2, 4, 8)? 7) What is your CPU usage set to (in playback engine dialog)? 8) What is your hardware buffer set to (ie - 256/512/etc)? 9) Which audio interfaces are you using? 10) Do you have the "insertion follows scrub" preference turned on in Preferences:Operations: ? 11) What is the bit depth/sample rate/audio file type of a session where this bug occurs? 12) Can you provide an exact series of reproducible steps to cause the bug to occur? If you are experiencing this problem and want to get it fixed, PLEASE reply to this post. Thanks! |
Re: ATTN: Mix hardware users - Scrub bug
I scrub a lot (FX editor) - and while I've never had any problems I thought I'd post my specs to compare against (sorry, I hope this of use to you). Dual 1GHz MDD G4 MIX Farm, d24, DSP Farm PT 6.2.3 cs1 Mac OS X.3.2 DAE buffer 2 CPU usage 99% 256 sample buffer 882 (old 16 bit) interface Insertion follows scrub is on 16/44.1/sd2 session type No expansion chasis - and a 32 voice playback engine. You don't specify which you're having trouble with. Could it be a bad card with you? Or are others having this trouble? |
ATTN: wave lab users THAT USE PT'S | sbag | Tips & Tricks | 1 | 02-01-2010 07:12 PM |
Attn: Logic Users | six mile hill | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-08-2003 01:59 PM |
ATTN: Sampletank users????? | Jayman#9 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-08-2002 08:39 PM |
Attn: D/FW Users | Esteban | Pro Tools TDM Systems (Mac) | 20 | 09-24-2002 09:00 PM |
ATTN: ALL SBLIVE! CARD USERS | notengo nombre | Digidesign Hardware & Software | 0 | 12-12-2000 04:31 PM |
