Old 04-25-2002, 09:10 PM
Pro Toolian Pro Toolian is offline
Default Please help Digi Tech Support !
So yesterday I was asking about latency with regards to the Mbox and Digital spdif inputs.
Here is what I need to know.
1. What is the minimum amount of latency I can get with Mbox using my Apogee Rosetta via the spdif input on Mbox using the lowest buffer setting (128) and will it be low enough to do any tracking and overdubbing?
2. Does Digidesign not intend the digital inputs of Mbox to be used for tracking?
3. Is the lowest amount of latency on Mbox using the spdif input the same as the lowest amount of latency on Digi001 using it's spdif input?
4. If the lowest amount of latency on the Digi001 is less than the lowest amont on Mbox then why was the Mbox made that way? Why not the same as Digi001 via spdif input?
Thanks again for your time and patience
Old 04-25-2002, 10:08 PM
ReniuR ReniuR is offline
Default Re: Please help Digi Tech Support !
<font size="2" face="Verdana, Arial">Well, I would guess that being that Mbox is usb, the data transfer isn't quite the same as a scsi interface. (This is just my guess, so don't kill me).
-ReniuR
www.disposableproductions.com
Digi Tech Support Chill Pro Tools TDM Systems (Mac) 3 03-19-2008 06:56 AM
DIGI TECH Support....WHERE ARE YOU? GORILLA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 18 02-12-2007 05:57 PM
C'mon, Digi tech support! Paul Cavins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-03-2006 07:10 PM
c/o Digi Tech Support Armando 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 08-29-2000 03:32 AM
Digi Tech Support A Diaz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-18-2000 08:14 PM
