Correct Load Order for ReWire Applications
So far it seems I've discovered that ProTools will not launch if Reason or Live are running. Live also is pesky in that it won't use the digi002 unless you bring up the plug first. (it will error and say no audio device or such) Reason seems a little more intuitive as the application launches when you select the plug.
Has anyone gotten live to work with built in audio? Reason can switch between the 002 and built in, but Live only seems to output to the 002. S. |
Correct order to boot PT and 002? | ChrisUK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-19-2006 06:30 AM |
Rewire applications | ondruspat | Virtual Instruments | 14 | 06-05-2006 12:33 AM |
What is the correct slot order in a g4. | michael.msuarez | Pro Tools TDM Systems (Mac) | 1 | 04-17-2006 08:35 AM |
List of Rewire-compliant applications? | Allan Speers | Pro Tools TDM Systems (Mac) | 12 | 07-09-2003 12:37 AM |
Correct order for PT Mix cards | Captive 8 | Pro Tools TDM Systems (Mac) | 1 | 10-16-2002 12:55 AM |
