Bug report: trimming a video file
Hey Digi.
Found a bug you might want to know about. - In PT 9.0.1, OSX 10.6.6 - Load a quicktime video. In this case, H.264 AAC - Editing of the video file is disabled (not sure if that's normal but I assume yes) - attempt to use trimmer tool on the left side of the video region - Screen draws a yellow outline of the trimmed video, but video does not trim. - yellow outline sticks on the screen and you can draw as many as you want. They stay regardless of zoom level. Email me and I can send screenshots. Cheers Adam |
Re: Bug report: trimming a video file
Actually - I can't MOVE the file video either, which I would say is unacceptable.
Wow - so I can't even move the movie file?? That's a big problem for me!
It's a real shock to me that moving a video file around in your session is a feature that you have to pay extra for.
A workaround, off the top of my head, is to set the session start time at the same time as the video start time and then import the video to the session.
The Postman Post-Production Studio Moncton, New Brunswick, Canada IMDb (very partial) |
Nope - it won't budge!
Not true, you CAN move video anywhere you want in vanilla PT 9. I've done it a few days ago when I needed to split a session into four reels, and in fact, I went to try it right after reading this thread, just to be absolutely sure. You cannot trim/split the video, but you can definitely move it the same way as any audio region. It is the same as it was in PT LE - you needed DV toolkit to enable advanced video functions.
If you can not move the video region, then the problem is in your setup. I'd try trashing preferences, it should cure it. Tom
BcA. Tomas Vitha Sound Designer and Mixer 2010 Mac Pro 8-core Westmere, OS X 10.6.6, PT HD 9.0.3, Mbox 2 Pro, C|24 |
fakir,
Thank you. I was worried there for a second. Trashed some files and it seems to be working! cheers adam |
No problem, glad to help.
Tom
Protools 8 LE bug report video, distorted audio PLEASE READ! | rootyjooser | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 12-09-2014 08:07 AM |
How do I file a EuCon bug report? | DLpres | Artist Series | 11 | 09-19-2013 06:51 AM |
Is video trimming still HD only? | TheJamsh | Pro Tools 11 | 6 | 07-16-2013 06:52 PM |
More than one video file in PT9 video track | ricardo.sousa | macOS | 6 | 02-07-2011 10:22 AM |
Bug Report: Noise at end of bounced file | nob turner | Pro Tools 9 | 2 | 01-24-2011 08:30 AM |
