Old 09-07-2021, 01:42 PM
BLG BLG is offline
Default Static on recorded tracks
This has come up before (in fact I've posted about it before) with no resolution but now it's back and it's worse than before. Now not only do I hear it during playback, but it's also in a bounced file (see link below).
I'm playing back/bouncing with the max buffer size (1024) - I know that when I play back with lower buffer sized I hear a lot of static. I think I recorded this with a low buffer and all plugins made inactive. I do have two lightweight plugins on my Master track/bus (Tonal Balance Control and Insight Pro both from Izotope).
Any clues about what could be going on? I'm running Windows 10 on a PC with 32GB memory and an Intel i9 processor. This is version 2021.7.
Sample (.mp3) sound with static:
https://drive.google.com/file/d/1zuz...ew?usp=sharing
Old 09-07-2021, 02:02 PM
Ben Jenssen's Avatar
Default Re: Static on recorded tracks
Doesn't sound like static to me. I don't think you should be looking for answers in PT, buffers, plugins and so on. Rather this must be coming from the guitar, cable, pedals, interface. You should be systematically troubleshooting your recording chain for a source of the problem. And deselect "Ignore errors during playback" in setup menu. It reminds me slightly of sample rate mis-match noise - are you using more than one AD in your input? Please give us more system details.
Old 09-07-2021, 02:28 PM
BLG BLG is offline
It's not coming from my recording chain as this is only on one group of tracks (8 tracks recorded in 4 takes with two mics on the cabinet (SM57 and Sennheiser e909)). I used the same setup to record 3 other groups of guitars and none of them has this issue. I basically go from my guitar -> amp -> two mics -> (one directly into a Focusrite 4i4 and the other through a Capi VP28 Pre-amp and then to the Focusrite) -> computer/PT.
Ignore Errors During Playback/Record is not checked.
Old 09-07-2021, 04:21 PM
cwsand's Avatar
cwsand cwsand is offline
Help Us Help You
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 09-07-2021, 04:58 PM
BLG BLG is offline
What are you looking for beyond what I've already stated:
PT version 2021.7
Focusrite 4i4
Capi VP28 Pre-amp
What else is there?
Old 09-07-2021, 09:35 PM
Top Jimmy's Avatar
PT version 2021.7
Focusrite 4i4
Capi VP28 Pre-amp
What else is there?
Sandra report.
Motherboard? System controller? All chipsets are not created equal nor do they perform equally.
Have you installed LatencyMon and monitored your system?
https://www.sweetwater.com/sweetcare...atency-issues/
James Cadwallader
Old 09-08-2021, 08:16 AM
cwsand's Avatar
PT version 2021.7
Focusrite 4i4
Capi VP28 Pre-amp
What else is there?
Everything is in the Help Us Help You link I provided.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
Old 09-08-2021, 10:54 AM
BLG BLG is offline
OK - I'll try to be more specific.
Before I do that I want to mention that this problem seems to have gone away for the most part. I hear static now and then but it's no longer throughout several recorded tracks. So while I initially thought this problem was something that I had intermittently and had gotten worse. now we're just back to intermittent. But when it's bad it's BAD! So I really would like to figure out why this is happening.
I don't know what motherboard is in my PC. I bought it as a Lenovo. It's an IdeaCentre T540-15ICK G. It came with an intel i5 but I upgraded to an i9-9900 running at 3.1GHz.
The storage is a 500 GB Samsung V-Nand SSD 970 EVO Plus NVMe M.2.
Video card is an NVIDIA GeForce GTX 1660 Ti.
2 ACER 32 inch Monitors - 1 connected via HDMI the other Display Port.
As I mentioned before:
32GB RAM
Windows 10 Build 19042.1165
PT version 2021.7
Focusrite 4i4 (connected via USB)
Capi VP28 Pre-amp
System controller? I'm pretty well versed in computers and even I have not heard of that as a separate unit.
Before someone blasts me for using an SSD as my primary (and only drive) I use an online backup service that gives me access to all of my data for the past 30 days, so reliability/durability isn't an issue. If that could be causing the static I'd want to know that though. The PC did come with SATA HD, but I unplugged it to save power after upgrading to the i9. I could certainly plug that in and try putting my data there. The system drive (where PT is installed) is SSD and there's nothing I can do about that.
I hadn't heard of LatencyMon. I'll definitely give that a try.
I can't run a Sandra report. I get Error (8112) Generic error!
Old 09-08-2021, 01:21 PM
BLG BLG is offline
I read through the Avid Help Us Help You link and found that I had Turbo Boost on in my BIOS which Avid suggests that you turn off. Turning that off seems to have helped, but I still hear a pop every 10-20 seconds.
I downloaded and ran the LatencyMon and everything is green. It reports no issues.
Thanks,
Ben
Old 09-09-2021, 04:57 AM
What plugins are on the tracks? Any demo plugins? If I had to guess I'd say it's intersample peaks going over 0dB and subsequent audio playing them.
Jack
QAPLA!
Static on recorded MIDI track during playback kksomersall Getting Started 1 12-22-2017 01:59 PM
Track recorded GOOD - Playback BAD - STATIC??? cjtowner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-20-2014 09:17 PM
static problem on tracks somefellow macOS 2 09-15-2012 06:37 PM
Have you ever recorded 16 tracks for 2 hours? Daniel P 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-09-2007 11:42 PM
recorded baby's heartbeat & want to remove static doublestakked 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-27-2006 04:33 AM
