DAE Error #-4 and -7100
Exisitng 96K/24bit session with 19 tracks.
1. Add Stereo Master Fader 2. Add Multichannel Fairlight Compressor to insert 1 Result: ProTools hangs up. spinning ball appears. A few of the tracks become disabled. ProTools DAE error -7100. PT is now unresponsive. Anytime I try to navigate, it takes at least 30 seconds for the program to respond. Action: try to enable the newly disabled tracks. I then get DAE error-4: ProTools encountered an error (#-4) while allocating voices. As a result, not all audio tracks were voiced. Action: Delete Master Fader. PT still unresponsive. Action: Quit PT (cmd-Q), PT unexpectedly quits. Action: Re-import all tracks to a new session.Add new Stereo Master. Same problem occures ONLY when I instantiate the Fairlight compressor. This is repeatable on this session but not on a new session.
AR | Audio araudio.net Monterey 12.6.1 MacBook Pro 2019 8-Core, i9, 32 Gb RAM AMD Radeon Pro 5300M 4 GB Ultimate 2021.12 HDX TB3 Chassis AVID HD 16x16 Analog I/O |
Re: DAE Error #-4 and -7100
check the answerbase on the digi site in the support section ....
for your convenience : dae error -7100 : Answer Details Sessions residing in "Read-Only" folders will cause Access Violations, -7100 DAE errors and -7453 DAE errors when attempting Audio Suite processing. Once these errors occur you must reboot your system to allow any further Audio Suite processing. Changing the session folder to a "Normal" status will alleviate these errors. -------- to check folder permissions got to info : command (apple) + i after selecting the folder. DAE error #4 or -4 ??? .... search gives different results .... varying from possibly defect hardware to file names that are too long (#4) try to read up on them and see if you can narrow it down to a possible solution. Good luck.
Chris Lambrechts Applications Specialist- Live Sound |
Perhaps the Fairlight is making a bad I/O connection to a DSP (hence the -7100). Curious if the required Accel DSPs are open when you activate the Fairlight? you could try importing the master track into a new session before all other tracks, or make other plug-ins inactive before activating the Fairlight.
(I'm investigating the Fairlight development status right now......) I'll be back! -tv
Tim vdB Avid Audio "There's a fine line between stupid and clever." |
This is irrelevant since the folder was not Read-Only and I was not Audio Suite Processing. DAE error #4 or -4 ??? .... search gives different results .... varying from possibly defect hardware to file names that are too long (#4) #-4. How do I attach my screen shot of the error message? My last posting has the full text from the error message. I'll keep searching that one. More Action: I added a multi-channel mono Fairchild compressor and it worked fine except the first time I muted it, there was a long zipper sound. Subsequent muting and unmute did not produce the same result. Thanks
here's the entire error message:
DAE error -7100 | nathand | Post - Surround - Video | 3 | 04-07-2010 01:08 PM |
Error 7100 and Error 4, tracks have no voices help | WannabeSQ | Pro Tools TDM Systems (Mac) | 1 | 08-10-2006 02:24 AM |
error#4 and error #7100, pro tools crash! | audioluche | Pro Tools TDM Systems (Mac) | 2 | 06-19-2006 06:10 AM |
PT6 error 7100 | AINSLIE | Pro Tools TDM Systems (Mac) | 8 | 03-19-2003 01:27 PM |
error 7100 | mario vejar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-28-2002 08:43 AM |
