external effects
hey.. im trying to use some external reverb effects because i run out of cpu power when i use too many plug ins. however i cant seem to figure out how to run the effects.. i set everything up and it worked but the reverb was mixed in w/ the original track. so my only control over the effect was on the reverb unit using the 'blend' knob. is there a way to have the original track dry, and have another track that is just the reverbed signal. so then i could mix the 2 together using the mixing faders?? and if so how would i do this?? thanks
Re: external effects
There's a section of the manual that covers using outboard effects. Look in the index under "bussing" or "busses".
Essentially, you use an aux send to a hardware output to the effects unit, and return it via a hardware input with an aux track receiving that input. Then you control the level via that aux return channel or send it to an audio track to record it. ------------------ LW
Larry PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins. |
External Effects | solivan2010 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 09-15-2010 08:52 PM |
external analog buss effects buss effects patching | bryanbassett | Pro Tools TDM Systems (Mac) | 10 | 10-07-2004 03:39 PM |
External Effects | surfengine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-12-2004 11:45 AM |
External Hardware effects VS plugin RTAS effects | boogiewoogie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-19-2003 06:25 PM |
External effects | GS-DK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 09-10-2002 06:32 AM |
